Crotch Rocket
TimChtrEvo
 Share
I see your V10 Viper based Sturgis 10...
and raise you a V12 BMW bike
http://paultan.org/archives/2006/04/30/hms...-dragster-bike/
Here's a better pic, the bike in the background is a harley for size comparison. Looks like a dragster chassis with a Viper engine crammed into it.
To call that rediculous or ludicrouse is still no comprehension of how out of this planet that is. The amount of tourque those engines have would never be able to be kept in control the wheels would continuosly lose traction into a wild spin my brother V rod does all the time.
A late model Sports bike these days weighs about 170 kg with a up to 190 hp. more power than wight they just raise the front wheel but I do not believe the bikes above would and if it did you would be in trouble as when th wheel comes back down the frame and forks could handle the impact.
These bikes above are show bikes and are amazing at that they are normally operational to ride on and off the trailor as the turning circle on them would be like a double bogie semi.
On the other hand a late model sports bike is another issue all together :P:(
OH I miss my bike :P:verymad::wacko: :wacko:
Keeping the front wheel on the ground wouldn't be the biggest problem with any of these but stopping the torque-reaction throwing you into oncoming traffic or simply body-slamming you into the bitumen definitely would be!!
 Share
    • Anything for a 2003-2005 G35 will fit an M35. Just be mindful about clearance if you're running a plenum spacer or runner spacer.
    • You know how I know I'm getting old? Because I feel this quote jells with me and SAU Forums, ha ha ha. I've gotten lost a few times as I had muscle memory to scroll to where I wanted on my phone and just click, now I'm lost... Ha ha ha     "I used to be with ‘it’, but then they changed what ‘it’ was. Now what I’m with isn’t ‘it’ anymore and what’s ‘it’ seems weird and scary."
    • You don't lose spark if your battery isolator isn't wired correctly and the ECU still has power from the alternator.   Car has an epic wiring problem. Sounds like power connected really really badly in places. Possibly a power pin on a ground pin for the ECU, and constant power in locations that should be switched ignition.   It needs someone good at diagnosing electrical, a good multimeter, and someone with the wiring diagrams to match the engine loom that has been put into the car, and wiring diagrams for the body side of things from the car.
    • Hi folks, what options exist for PNM35 or what models share the same dimensions and fitment for the front top of tower strut brace. I have seen a few options pop up through Google, the Ultra Racing Australia for one. I have seen some eBay ones that claim they fit C34 and M35 but can't find details if to work out if its true. Also found Taiko / TEMA4x4 claim the one type fits: - Nissan Stagea (2-nd gen; M35) 2001 - 2007, - Nissan Skyline (V35, HV35, NV35, V35, PV35) 2001 - 2007 - Infiniti G35, G35X (3-rd gen; V35) 2002 - 2006 But not sure how true that is. Anyone fitted one or know of someone using one and can confirm what does fit?
    • I got the full kit.   The compressor as above is much smaller and lighter.  Also quieter. Bracket is visually mint and much lighter. The dryer and heat exchanger(rad) are one unit. Also smaller and lighter.  Much more room for an oil cooler. The fan I got was a bit Meh and I might change it.   And above all else it is more efficient, tested a good 3-4 degree's cooler than the old system, which is a lot. Disclaimer though - It wasn't a back to back test given different days. It really does feel colder though(always).  And this example is in my car with that crusty looking old compressor, not new vs new
