Hi Guys,
finally getting to stage where I can get the my GTR changed into ACT rego.
the only problem is I have 2 sets of wheels choices to get over th pits with, which one would be more likley to pass?
I have a set of TE37's 17x9+15 with 245/45R17 which stick alittle past the guards
or
a set of TSW REVO's 17x7.5+?? with 215/45R17 which stick inside the guard abit.
Which one do you think would be better to go over the pits with?
(P.S. both wheels clear the brakes)
cheers
Michael
P.S. still thinking of a good name to replace YAF28F.
Hey Michael,
the TE37's will not pass anything that sits outside the guard is an instant fail. put the 17x7.5's on. it will not matter if they are in the guard quite a bit.
cheers
Not quite Cef11e..
You'll also need to ensure that with the wheels sitting in the guard a fair bit that they DO NOT come in contact (foul) with anything at full lock both ways.
As in, if it just touches any part of the guard, then it's also an instant fail.
So the wheel needs to be able to full lock left and right without touching anything.
The wheel and tyre must not foul any part of the body or suspension under all operating conditions.
http://www.rta.nsw.gov.au/registration/dow.../vsi09_rev4.pdf
Edited by Ecstasy
it depends if the wheels increase or decrease the track of the car. you only get a certain amount of mm each way. PM Bluprint about it. he is still dealing with a similar problem and will know alot more about it than me...
you can increase track by 25mm (from memory) and diameter by +/-14mm
Going through engineering on another car at the moment. track is measured from the centre of the wheel,
so widths and offsets can make a big difference here as to what can and cant pass. The usual, rubbing, sticking outside guard etc. also applies to this
Wow, thanks for this, Might have to take the time to fit all 4 wheels on for the TSW to see if it rubs against anything first.
I'm hoping the width of the tyre won't fail as standard R32 GTR tyres are 225 and I'll be using 215's
maybe it's time to invest in a set of stockers.
one other interesting thing is that all 4 wheels must be the same width e.g. 17x7 front and back or you have to get an engineers certificate like i did to run larger wheels on the rear e.g. 17x7 front 17x8 rear, note this is only if the car was originally sold with this setup it dose not apply to allot of newer cars
Okay, rather than saying stuff without backing it up, here is probably the best thing I can do..
www.rta.nsw.gov.au - VSI 09 - Guidelines for alternative wheels and tyres (Nov 2003)
From -
http://www.rta.nsw.gov.au/registration/dow...si/vsi_dl1.html
Edited by Ecstasy
    • Yeah I'm happy to talk to whoever, I don't want to take ownership or even manage it if they don't want but I can probably help with hosting on the sau setup. It's a great resource and should be protected.
    • So, got some bits..   New oil filter housing gasket (main problem I'm trying to fix -see leak above)  While you're in there's: New belts, pulley and tensioners.  Vanos oil line New oil drain valve New water pump and pulley  New fumoto valve (all my cars have these). Some of this stuff seems ok now that I've pulled it out but I still have no idea how old it all is.  The belts looked fine and then I noticed this. Like somebody has hooked it with a pick.
    • As the title suggests, Looking for some comfortable replacement seats that will suit/fit an R32 GTR. Purely road use.  Happy to travel to the Tweed, Gold Coast and Brisbane area. Possibly Sunshine Coast for the right seats. Show me what you got! Thanks in advance.
    • Customer states,I got an oil leak.  Customer was raht.
    • Hi friends, I recently got myself back into an R32 GTR with factory seats. The seats themselves are in excellent condition but the drivers seat is a bit tight for my back and become uncomfortable after about 20min of driving. The passenger seat is a little better so I'm not sure what is going on there, almost as if the drivers seat is newer and has not been worn in.  Anyway, I'm looking to replace them with something thats going to be comfortable for road use.  I was looking at these replica seats from Crank Motorsport however there has been a number of reviews of the company that aren't great so i'm a little skeptical.  https://www.ebay.com.au/itm/185466689021?_skw=r32+GTR+front+seats&itmmeta=01JKS72VG115M2Y3KBGCBCWYDD&hash=item2b2ead15fd:g:cMAAAOSwhhZlsIpK&itmprp=enc%3AAQAJAAAA8HoV3kP08IDx%2BKZ9MfhVJKl6v17FmqPFPHrHp4kFm2I9VMAXrpZg5R8sUXH6QLUAkliQu34NiG%2F84PJ05lKf2iGboUiWpWbvHYPYKsT154rul3I%2FaGRskpG8VfgyrwC9%2BdRj7uoDAPGJH%2FVprfvd6pgAN2XmUz6buE9YHvOPCKhtJfsQXhEzwgmVTcIwEkkV0A1r%2FkyJYMmQK0OKLI%2FrM%2FQLzeAOkN9B6WLAPrNyFlml%2FkG%2BYzkTXGJ8LN%2B0NCSLfczQGSYeJqPfvMFMgDL2gOD%2BPWb3sX1D1A6PxY5jqyMGey7zin4sDqrUrA7CpqLLpA%3D%3D|tkp%3ABFBMmriLp55l I also live In the Northern Rivers and these seats are in Melbourne so I can't even try them out before purchase.  Is there anywhere/anyone around the Gold Coast, Tweed or Brisbane area that would have a decent selection of seats I could test out before purchase. A lot of these places seem to be in Sydney and Brisbane. Maybe there's an individual who has an after market item such as Bride or Recaro I could quickly try? Thanks in advance!
