ragex Posted September 24, 2007 Share Posted September 24, 2007 what sort of torque does a modded rb25det make? Link to comment https://www.sau.com.au/forums/topic/186433-my-rb30det-r32/page/2/#findComment-3370747 Share on other sites More sharing options...
MZTRBO Posted September 24, 2007 Share Posted September 24, 2007 Also, good stuff on the budget build...Im putting a rb25det in my r32 and changing my mind now as I want the 3.0l bottom end. Do it once I say.. Link to comment https://www.sau.com.au/forums/topic/186433-my-rb30det-r32/page/2/#findComment-3370749 Share on other sites More sharing options...
lwboosted Posted September 24, 2007 Author Share Posted September 24, 2007 i was under the impression an 040 fuel pump was good as well... lol Link to comment https://www.sau.com.au/forums/topic/186433-my-rb30det-r32/page/2/#findComment-3370876 Share on other sites More sharing options...
The Mafia Posted September 24, 2007 Share Posted September 24, 2007 I just looked at the torque figure - holy farken shit You're making 670nm at 230rwkw at the same RPM as me. I'm making 702nm at 300rwkw at the same RPm... so at 300rwkw you'll make probably 150nm+ more! going to be a f**ken monster. Goodbye tyres! ahaha Link to comment https://www.sau.com.au/forums/topic/186433-my-rb30det-r32/page/2/#findComment-3370933 Share on other sites More sharing options...
Roy Posted September 24, 2007 Share Posted September 24, 2007 Was devastated we didn't get to wind it up... can't wait to finish it off RPM Scale - This is a guide only and was done as an rpm vs road speed from the tacho. Tuning was by no means finished, even on minimum boost, due to severe boost leaks When its all finished i would love to see his dyno sheet overwritten on my RB20 graph from when we compared my RB20 with TD06 against Phils RB20 with HKS GT-RS. It looks to be making about double what i make at 3,000rpm and the little 20 doesnt catch it until 4,700rpm Hm...should i throw away the RB26 bottom end? When you get it all sorted Leigh i woudl kill to be taken for a drive in it Link to comment https://www.sau.com.au/forums/topic/186433-my-rb30det-r32/page/2/#findComment-3370959 Share on other sites More sharing options...
Cubes Posted September 24, 2007 Share Posted September 24, 2007 Mafia, Here's a friends old mainline dyno sheet. The car was running an XR6T turbo 1.06 rear, rb30det. Inlet/exhaust manifolds all standard. I believe rev cut was at 7000rpm. Dyno roadsped appears different so no doubt a torque comparison is out of wack. Why don't dyno operators just leave it as a set value so we can all compare easily. ---- Where does it make its 13psi? ~3k? Link to comment https://www.sau.com.au/forums/topic/186433-my-rb30det-r32/page/2/#findComment-3371108 Share on other sites More sharing options...
lwboosted Posted September 25, 2007 Author Share Posted September 25, 2007 yeah roy no worries i will take u for a spin... as soon as the silicon joiners come in i will be going up to get it re tuned.. so i will keep you posted.. oh does any1 have a spare rb30 bottom end in good condition.. haha just preparing for when this one goes BOOOOOOOOOOOOOOM!!! hahaha when i go to wind up the boost how far do you guys think i should go?? i want it a little reliable i dont want to be going through bottom ends every month... i was thinking round 17-18 psi??? Link to comment https://www.sau.com.au/forums/topic/186433-my-rb30det-r32/page/2/#findComment-3372502 Share on other sites More sharing options...
Cubes Posted September 25, 2007 Share Posted September 25, 2007 Sky30's 320,000+ km RB30 held 380rwkw and prior to that 312rwkw without problems for quite some time. Providing you don't rev it past 7k on its stock rods, motor is in good nick and tuned well it will be fine. Rbman's currently has his stock rb30 bottom end reving to 7.3k as its holding power well to that rpm; doesn't appear to be having issues. I have my limiter at 7k; still haven't quite got the hang of keeping it off the limiter in first and second. I recently gave the subframe 12mm rake which has improved weight transfer 2x; I can now feel the arse end slightly sitting down instead of what felt like lifting up and spinning with very little forward movement. Go 18-20 pounds; you do have lower than 8:1 static comp so it will be fine on pulp. Link to comment https://www.sau.com.au/forums/topic/186433-my-rb30det-r32/page/2/#findComment-3372654 Share on other sites More sharing options...
Dale FZ1 Posted September 25, 2007 Share Posted September 25, 2007 I just looked at the torque figure - holy farken shitYou're making 670nm at 230rwkw at the same RPM as me. I'm making 702nm at 300rwkw at the same RPm... so at 300rwkw you'll make probably 150nm+ more! Checking your dyno sheet, it appears that they both make approximately the same/very similar torque (and therefore power) at 115km/h. Then the higher boosted 25 makes and holds a higher figure to generate the power recorded. Makes sense really, with power being a function of torque and rpm. Wait until this 30 gets fed a bigger mass (via boost) and hopefully gets some bump sticks that allow it to breathe more effectively. Even if rpm is governed to less than 7k, it will make some pretty good grunt. If the current peak power rpm @ ~5300 is anything of an indicator, the torque will be stupendous. Dyno roadsped appears different so no doubt a torque comparison is out of wack. Why don't dyno operators just leave it as a set value so we can all compare easily. What's the difference attributable to? Hasty setup and calibration by the operator, or some real difference in gearing ie. tyres, final drive or gear ratios? If it's a 32 chassis, is it still running a 25DE spec final drive? Some times it's very good to review the graphs using both engine and road speed. I have an old chart from my bike being dynoed through the gears, before/after final drive alterations. The amount of extra grunt hitting the road in any gear, at any sane speed was significant. Link to comment https://www.sau.com.au/forums/topic/186433-my-rb30det-r32/page/2/#findComment-3372984 Share on other sites More sharing options...
foznice Posted September 25, 2007 Share Posted September 25, 2007 Awesome work Leigh, congrats! Shotgun a ride when she's making insane amounts of power... The 25 is still in my wardrobe by the way, and parents still have no idea. I run out of money. But it will all happen... one day. Link to comment https://www.sau.com.au/forums/topic/186433-my-rb30det-r32/page/2/#findComment-3373028 Share on other sites More sharing options...
Cubes Posted September 25, 2007 Share Posted September 25, 2007 What's the difference attributable to? Hasty setup and calibration by the operator, or some real difference in gearing ie. tyres, final drive or gear ratios? If it's a 32 chassis, is it still running a 25DE spec final drive?Some times it's very good to review the graphs using both engine and road speed. I have an old chart from my bike being dynoed through the gears, before/after final drive alterations. The amount of extra grunt hitting the road in any gear, at any sane speed was significant. Its an R32 chassis.. Setup by the operator is what the problem is. Mine making its peak power at 6k with basically the same turbo is starting to make me think getting a little head work and port matching done is most definitely worth its while. Can't wait to get the lumpy 805c grinds in to it. Link to comment https://www.sau.com.au/forums/topic/186433-my-rb30det-r32/page/2/#findComment-3373249 Share on other sites More sharing options...
PHaT MR30 Posted September 26, 2007 Share Posted September 26, 2007 Wow leigh, great to see the turbo found a good home, looks like your gonna make some mad power with it too! Gutted I never got to use it! Link to comment https://www.sau.com.au/forums/topic/186433-my-rb30det-r32/page/2/#findComment-3373896 Share on other sites More sharing options...
Blaise Posted September 26, 2007 Share Posted September 26, 2007 ...wow was lucky enough to have a ride in this weapon yesterday, the torque is absolutely unbelievable. Having basically no traction till 4th is definitely a thrill too. Congratulations Leigh, absolutely siked for you! Link to comment https://www.sau.com.au/forums/topic/186433-my-rb30det-r32/page/2/#findComment-3373958 Share on other sites More sharing options...
bombtrack Posted September 26, 2007 Share Posted September 26, 2007 That's great, congrats! I am thinking of doing the same in my 34. Where'd you buy the motor from or did u have a VL/R31 for parts? Cheers. Link to comment https://www.sau.com.au/forums/topic/186433-my-rb30det-r32/page/2/#findComment-3374122 Share on other sites More sharing options...
Mitchee Posted September 26, 2007 Share Posted September 26, 2007 Out of interest, did you do any timing belt tensioner re-locations, and which timing belt did you use? Link to comment https://www.sau.com.au/forums/topic/186433-my-rb30det-r32/page/2/#findComment-3374165 Share on other sites More sharing options...
NickR33 Posted September 26, 2007 Share Posted September 26, 2007 did you use fresh rings or just grab the bottom end and bolt it up? impressive effort in the time spent, even more so if you had the bottom end apart making me wish I went 3L... torque animal! no more china tires for you! Link to comment https://www.sau.com.au/forums/topic/186433-my-rb30det-r32/page/2/#findComment-3374334 Share on other sites More sharing options...
TTT Posted September 26, 2007 Share Posted September 26, 2007 I love that it "really" is a stock bottom end. no refresh of anything. take the sohc of and bolt in the dohc. add valve springs and other bits required and turn the thing on Link to comment https://www.sau.com.au/forums/topic/186433-my-rb30det-r32/page/2/#findComment-3374622 Share on other sites More sharing options...
lwboosted Posted September 26, 2007 Author Share Posted September 26, 2007 Go 18-20 pounds; you do have lower than 8:1 static comp so it will be fine on pulp. 18-20 pounds it is.. haha That's great, congrats! I am thinking of doing the same in my 34. Where'd you buy the motor from or did u have a VL/R31 for parts? Cheers. i just bought a rb30 off a mate for $100.. Out of interest, did you do any timing belt tensioner re-locations, and which timing belt did you use? yeah i bassically just followed the rb30det guied in cubes sig... did you use fresh rings or just grab the bottom end and bolt it up? no freshen up just a bog stock bottom end with the head bolted on top.. just as GTST says... thanks guys for all the coments!!! just heard the silicon joiners are in the mail so hopefully they wont take too much longer.. Link to comment https://www.sau.com.au/forums/topic/186433-my-rb30det-r32/page/2/#findComment-3374765 Share on other sites More sharing options...
Simon-S14 Posted September 26, 2007 Share Posted September 26, 2007 i think ive gotta do this soon lolol Link to comment https://www.sau.com.au/forums/topic/186433-my-rb30det-r32/page/2/#findComment-3375047 Share on other sites More sharing options...
vinnie32GTS4 Posted September 26, 2007 Share Posted September 26, 2007 hey just a quick question..just say u had a 32 gts4 or a gtr and u wanted to do the rb30 bottom end with rb26 head would u be able to keep the awd(atessa) in? would it fit or would u have to remove it?? Link to comment https://www.sau.com.au/forums/topic/186433-my-rb30det-r32/page/2/#findComment-3375663 Share on other sites More sharing options...
