yippee, my ride is finally back on the road!. i went and picked her up yesterday from integra and anthony showed me the official report from GCG with photos and all. I'll post some pics up later when i get a chace to scan them. but after looking at the pics and discussing with anthony how this could have happened we came to the conclusion that i haven't had my turbo timer set for long enough. i was an aware that ball bearing turbos require longer to cool down than leaf turbos and 2 mins of turbo timer is just not enough after a hard drive. so after all that it turned out it was my fault for the turbo dieing, apparently i should be letting the turbo run down for at leaset 5 min, i only wish they could have at least given me that info when i had it high flowed in the first place. you would think it would be critical information that a customer should be given. but any way she's back on the road and I'm slowly working the turbo in on stock boost for a while. and very happy to finally have my car back :ninja::P
Mines stock, so can someone tell me how long I should have my timer set for after a normal street drive (nice'n'easy one that is)? If I'm only putting around, I have only been giving it about a minute or two.
There are many varying opinions on how long a car should be left on to let the turbo cool down.
Personally I never really leave it for any longer than 30 seconds unless it's been a hard drive and I've not done a 'cool down lap' on the way to my destination.
Well if these turbo shops are claiming "oil contamination" as the cause of failure, i would personally send a sample of the oil to be tested. Funny how the standard turbo lasted 15yrs, with the oil passing through the same lines and i'd bet "oil contamination" wasn't the reason why it failed :worship:.
Once the oil has been tested and if the results show no metal rust contamination, then i would hit the company for replacement turbo, test and fitting costs.
yippee, my ride is finally back on the road!. i went and picked her up yesterday from integra and anthony showed me the official report from GCG with photos and all. I'll post some pics up later when i get a chace to scan them. but after looking at the pics and discussing with anthony how this could have happened we came to the conclusion that i haven't had my turbo timer set for long enough. i was an aware that ball bearing turbos require longer to cool down than leaf turbos and 2 mins of turbo timer is just not enough after a hard drive. so after all that it turned out it was my fault for the turbo dieing, apparently i should be letting the turbo run down for at leaset 5 min, i only wish they could have at least given me that info when i had it high flowed in the first place. you would think it would be critical information that a customer should be given. but any way she's back on the road and I'm slowly working the turbo in on stock boost for a while. and very happy to finally have my car back :worship::(
Sorry to say that sounds like complete BULLSHIT.
Unless you are thrashing the car to the driveway, smoking the tyres till you park, 2 mins of turbo timer is MORE than enough. Hell if you drive normally for the last few minutes of your trip, then 30secs is enough. My turbo timer is set to 20sec, and unless i am competing in a motorsport event, i never increase the time and my HKS turbo has never had a problem.
The only other reason of failure, is that the turbo wasn't primed/lubed before starting the engine for the first time, thus causing the bearing to heat up and score, during the initial few seconds
Back to the turbo:
How long did it take till you delivered the turbo, to the time you received the report.
Not saying this has happened, but can you be sure those pics are from your turbo?
Not saying that the company involved is responsible, it could have been an installation issue (refer above about primming), but the turbo company has specified oil contamination, so get the oil tested.
as far as i know around 2 to 2 and half minuets for the stock turbo should be fine, as it is not ball bearing
Actually they are Ball Bearing and BB need less time then Bush bearing to cool down and are more tolerant to quick heat and cool then bush.
Some correct me if I am wrong...
yippee, my ride is finally back on the road!. i went and picked her up yesterday from integra and anthony showed me the official report from GCG with photos and all. I'll post some pics up later when i get a chace to scan them. but after looking at the pics and discussing with anthony how this could have happened we came to the conclusion that i haven't had my turbo timer set for long enough. i was an aware that ball bearing turbos require longer to cool down than leaf turbos and 2 mins of turbo timer is just not enough after a hard drive. so after all that it turned out it was my fault for the turbo dieing, apparently i should be letting the turbo run down for at leaset 5 min, i only wish they could have at least given me that info when i had it high flowed in the first place. you would think it would be critical information that a customer should be given. but any way she's back on the road and I'm slowly working the turbo in on stock boost for a while. and very happy to finally have my car back :P:)
wow smells like bullshit. looks like they're trying to give excuses now.
like Al says, i think it's only really mandatory to run your turbo timer for 2 minutes if you've been bashing the limiter all the way home. i'd be going back for complaints.
drive normally for 5 minutes after a thrash, and with a bb water cooled turbo it's doubtful you'll need to cool down more anyway.
and if you haven't thrashed it then normal shut down without a cool down is fine ie manoeuvering into the garage after cruising down the street is enough.
Edited by Scooby
Back to the turbo:
sorry i've been away for a while working on a feature film being filmed in goulbourne. now that you metion it one thing i found realy fishy is the photos taken of my turbo have a date stamp of early 2004.
    • Interesting. Some of them were tight to lol
    • That's right, simple but works. Run out of load? Rescale the table lol. Want to be lazy and not rescale? Drag the K
    • @DraftySquash @Duncan he's not talking about the part that sits against the radiator support, he’s talking about the lip that sits towards the front outside of the car. anyway I had a look at other cooling panels and came across this one https://justjap.com/products/carbing-radiator-cooling-panel-plate-nissan-skyline-r34-gt-t?variant=37829684134087&currency=AUD&utm_source=google&utm_medium=organic&utm_campaign=Advanced feed&utm_content=Carbing Radiator Cooling Panel Plate fits Nissan Skyline R34 GT-T (Coupe)&srsltid=AfmBOoonzPDKqe9NgKi5U0AkFc2XvbXETGmNWvfNcyBT5DUZagMYHg9DZ70 if you take notice it’s the same shape.  well thankfully the justjap listing has a description and it says : - Nissan Skyline R34 GT-T Coupe (M/T -07/2000) this means it’s specifically for a s2. S2’s have different front bars to s1 so that lip with the 3 holes are *probably* mounting points for the s2 bar. im not 100% sure but im almost certain it will still fit a s1 bar
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
