everyone knows how horrid the r34 gtt stock gauges are so im about to replace them with a set of defi gauges. if i purchased another 2 i would get a good deal.
so the question is, what 5 gauges should i get? i understand that boost, water pressure, oil pressure, exhaust temp, manifold pressure are popular ones.
basically what 5 gauges would u set up in your car if u had the chance
Edited by R34NRG
https://www.sau.com.au/forums/topic/186440-defi-gauges/
Ive got defi's for my r34gtt - boost / water temp / oil pressure / oil temp / big defi tacho with shift light
only other one im looking at getting is exhaust temp....helps you know when your about to melt things :domokun:
have u got any pics mate? would love to see em!!!!
wat colours did u get?
me personally am going for the red set
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3370313
1. PSSSHT value
2. CHUCHUCHUCHU-meter
3. +40PSI reading boost meter
4. 8"-12" monster tacho
you know me, id get em if i could :domokun:
do we have any SAU traders that sell defi guages?
would like to compare prices
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3370336
havent fitted them yet to the r34 yet took them out of my ceff when i sold it and now i have the r34 i'll whack them in when i get some time (and a sandwhich plate)
i went the white black outs exept for the tacho its the other version as they didnt make a black out tacho (bugger)
got them through cj motors off the silvia forums he's in brisbane and super fast turn around for stock...i highly recomend him.
apparently the exhaust temp will also give you a hint as to when stuffs leaning out...or so ive been told by a few workshops so im looking into sourcing one before i install the rest of the set..
be sure to post pics when its done man!!!
they been going for around the $215 mark but ive seen some for $250.
how much did this brissey guy give em to ya 4
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3370357
I have,
Oil temp
Oil pressure
Water temp
Exhaust temp
Fuel pressure
Turbo
5 mounted in the centre part where air cond stereo etc used to be
and near the a pillar
you've also got to mount the control box somewhere too. so keep that in mind!
but this is in a 32 gtr
Edited by Angus Smart
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3371362
im not a expert but could someone explain why oil pressure would be more importent then......lets say for arguments sake manifold press?
just to get a better understanding of what my setup on my type of driving could be suited for
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3371579
manifold pressure would be quiet similar to boost pressure/turbo... (i think)
oil pressure is probably the most importiant out of the lot, without pressure how are your internals going to survive!!
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3371604
Because low oil pressure is a hell of a lot more pressing problem than low manifold pressure and indicates a serious problem such as oil pump failure, oil surge etc. Something you'd be really keen to playback after a hot lap.
Besides the manifold pressure gauge is for a NA car if i am not mistaken.
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3371619
Horrid? Nope. I think they aren't bad for stock gauges unless you are aiming to impress Paul and Vin when V-tec kicks in yo.
Admittedly I've upgraded to the Nismo gauges but hey, they work.
I'd like to see -
1. Dose/flutter meter
2. KM's to Noble Park Macca's
3. RPM till V-tec kicks in yo
4. $ left till I've payed the car off
and last
5. Number of Bush cops I've noted on the way to Noble Park Macca's
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3371650
Because you car's blood is oil, no oil = dead engine. Low oil pressure = problems so it's nice to know what's going on.
Manifold pressure means nothing unless your floor pan falls out when you exceed it's limit, most likely from too many NOS shots.
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3371664
If your oil pressure has dropped off, the damage is already done.
Especially @ 7000rpm. IMO the oil pressure isnt that much of a help (over the stocker gauge). As ye, once you've done your dinner... thats it.
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3371668
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
