yeah i got a new lower control arm when i got it fixed and also got the wheels aligned but still pulls a bit not sure why i totaly replaced all of the suspension on that side so maybe its the steering rack didnt check that
Not the whole rack, the rack end and tie rod end. Could be a slight bend in there.
Also what castor bushes do you have? Are they adjustable? Are you 100% sure they are fitted correctly?
Tom, have you not got new tyres yet?
No, These ones aren't too bad, there is a little bit of inside wear on the right front but thats it.
I am scouting Nengun and contemplating whether to get 4 wheels in 1 hit and suffer a $200+ import tax or just 2 now and order 2 in a few weeks to save on the tax. If I order all 4 now I will have them in time for the Xmas cruise...... Dilema.
i know that my tie rod ends are leaking could that have anything to do with it? i think i just have stock castor bushes so i dont think that they are adjustable but am not sure
Would probably need to have a look at it some time. Something is not right :D
yeah there is always something not right with cars im struggling at the moment to find funds for insurance, stupid insurance companies *shakes fist*
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
    • He means "as opposed to mechanical cable drive". Older cars (R32 for ex.) had cable drive. Later cars with essentially the same gearbox, ie R34 GT (NA RB25) used essentially the same box as the R32 GTSt, but instead of a cable drive, had an electronic speed sender plugged into the same hole in the box, running from the same little gear that would have run the cable. Some of the shittier later cars use a speed sender on the nose of the diff, or the ABS sensors.
    • Lower than engine, or lower than it should at the hubs? Either way, that is a nice power figure and I'm not surprised you say it rips now. What stopped you from turning it up any more? Injectors? Or did it just stop responding to boost?
    • Got my 34 gtt tuned last week. Car made 362 wheel horsepower at 19 psi. Turbo was the ATR43SS. Only other upgrades were haltech 2000 series. 650cc injectors, walbro 250, fmic. Pro hub dyno reads 6% lower than actual figure according to my tuner. Car is a real ripper now.  IMG_7261.mov
    • Hi everyone, I'm wondering if anyone in Melbourne (preferably West) has a non-S2 R34 front bar. If it's already off the car, even better!  Nothing too weird, I just need to get a cut-out of the hole that the front indicators clip into 🤣 (image attached for reference)   I've got a front bar from JSAI Aero, but those holes need to be cut myself, and I want to get it right so the indicators will clip securely. And my OEM bumper is a S2, so I have no reference. So looking for a member who might be able to spare me a few minutes to make a cardboard cut-out using your front bar.
