The tutorials in the search are coming up with 32 , 33 fuel pump installs only, I followed the guide and got as far as taking the lid off and looking inside, I cannot see a pump, just a hose and two wires running up to the front of the tank cannot see anything else at all. Does this mean I have to take the tank completely out ??? Any help greatly appreciated.
https://www.sau.com.au/forums/topic/186449-need-help-walbro-fuel-pump-r34-gtt/
you wont see the pump it is down the bottom of the tank
usually theres a metal cradle that it sits on that is slid in a slot somewhere up the top... have a look better and you should see... probably follow the wires as they are most likely the positive and negative feed to the pump
unless im completely wrong and an r34 is very different to r33
Reach into the tank with the palm of your hand facing towards the front of the car. Grab the metal bracket you will find attached to the inside front of the tank. Pull it up to slide it off it's mount. Pump is attached to the bottom of it. Pull the whole thing right out.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
