Whats the difference between normal GTS-t series 2 and Spec M.
I have just put in front mount intercooler. The standard intercooler is bigger in spec M than normal series 2.
I dont know any other differences? I have searched but cant find much on it.
Is the turbo the same?
https://www.sau.com.au/forums/topic/186463-skyline-gts-t-spec-m-series-2/
BIgger or smaller, they are all made to handle the stock poewr level without breaking a sweat. Any significant increase in power would require a bigger intercooler anyway....so a small increase in SMIC size is really a moot point.
  vladinator said:
but what are the differences?
do you have M spec?
The only "M Spec" is a rare R34 GTR of which shit all are in Australia.
What you are reffering to is Type M!!!!
The Type M R32's came with 4 pot brake calipers (front) thats about it. Some had body kit, 16" rims, climate control but that could all be optioned on 32's anyway, different dealerships offered a different combination of add on's with the type M.
So essentially, sayin you have a type M doesn't mean anything, just about every gts-t is type m
The M-spec is sexy. I think it was the luxury version of the 34 GTR's.
The type-m was just a package as far as I know. A package with the optioned things as standard? I'm sure a search will answer that though.
^^^ Correct,
any series 2 R33s are type M's
As far as i know the only difference is the side skirts, rear pods and POSSIBLY the lip on the front bar???
Everything else would either be aftermarket or a series 2 thing, not a type m thing...although as said, type M's are series 2 r33s anyway.
  MSPEC33 said:
AND with the 33 GTS25T TYPE M - wasnt there an offering of a different suspension option.
yeh mine comes with different suspension but i dont know if that was fitted afterwards or came with the car.
thnx for all the replies
  MotoMan said:
You can have a R33 Series 2 type LM aswell
its the series 2 R33 with the gtr vspec Active LSD
Actually it was known as the 'GTS25t Type M Active LSD', not 'Type LM'.
Infact even before R33 GTS25t type M.. All series II R32 GTS-t's were type M SOOO ever since 1991 all 2 door GTS-t's are type M...
there was 1 r33 GTS25t type G but that was a 4 door
So unless you have a R32 GTS-t series 1..( which can be a type M ).. or unless you have the Rare 4 door type G then you definately have a GTS-t type M..
:P
    • Definitely didn't put a N/A cluster in instead? The speed sensor (location) is different in both cars.... I think. This will obviously stuff things up.
    • Nah not the throwout bearing, it's something internal. I already replaced the throwout bearing. Mechanic misdiagnosed my car and thought it was a spigot bearing, went to another bloke who said it was an input shaft bearing. (I replaced everything when I pulled out the gearbox but didn't open up the gearbox.   In this video at timestamp 6:05 : Mine has the same sound  min
    • It is definitely to space it out and away for clearance during compression, and possibly for spring clearance to upper arm. That latter would only be true for springs that are same-ish diameter to stockers, and so that probably doesn't apply to Teins or most other coilovers.
    • Yeah, a mechanic who knows these cars told me even if I get a brand new gearbox the noise will return but will be less noticeable. I've heard someone also they this noise came back after 3,000km on a new or reconditioned gearbox. It is pretty f**king annoying though just hearing groaning most of the time lol. I wonder if an aftermarket input shaft bearing would fix the problem or how they are built.
    • All RB gearbags, especially the big turbo box, have rollover noise. Mine certainly does. Always has. Sometimes is worse than others - no particular idea why, although it is probably temperature related. I have smurf jizz in mine and have had to have it in there from the first day the box went into teh car. It simply would not select gears with the engine on, on day one, with normal oil in there. And so, the blue stuff has probably ruined almost everything synchro related in the box. But it has taken 12 or 13 years to get to the point where I simply must replace the box. It has become increasingly baulky of late, which might be symptomatic of the way I've been driving it, as much as anything. I shall have to make some corrections when teh new box goes in. Input shaft bearing noise will decrease with clutch pedal pressed because the drive is removed. But yes, more often than not noises that work like that are associated with the throwout. It won't matter either way, new box will mean this one can be relegated to the parts pile.
