OK, so mine is broke and the boat needed a tow home. BOO!
UAS have clutch pivot points for sale for 55bux.
Can I DIY? And do I need to take the box out to replace this sucker?
ALSO, how the HELL do you get the for retaining spring off? Is there a knack to it?
Cheers guys,
https://www.sau.com.au/forums/topic/186490-help-replacing-clutch-pivot-ball/
yeah you have to take the box out to replace it. 55 beans is ok nismo ones on here are the same price. the retaining spring comes off just how it looks just flick it off
yeah I put a nismo one on mine as well, as my OS twinny broked the standard GTR one. box def needs to come off for it.
old one:
new one:
Got it from JDM Concept, one of the sponsors on the forum.
Its easy enough to get it off but can you put the new one back? I can tell you that I can't but if you have very small hands you maybe able. Interesting to see if you can do it , even if it takes half an hour will be worth it .
think the genuine nissan replacement R32 GTR/R33 GTSt one was $22 or something including delivery to the workshop. The Nismo ones are $55 - $60 depending where you get em from (or $90 and 2 weeks wait from Nissan) and apparently 30% stronger. You only need the strengthened one if you're running a twin plate or a clutch which requires a lot of pressure.
Good thing I'm getting the heavy duty one! (I have a 2500lbs single plate with a ceramic clutch) - yes, its REALLY heavy under the foot!
I'll let you all know how I go putting the new one in (yes, this man has pretty girly hands - blame computers)
Funky,
I'm running the GTR Exedy 3puk button NSK-7121SC. Required do you think?
My last xtreme 9puk XHD I noticed the slave cylinders pin had been crushed back and had a slight wobble in it; possibly why I had slight issues with disengagement. The 9puk was heavier on the pedal than a mates OS Giken twinplate that he has in his GTST.
I'd get the nismo one cos its worth the extra $20 or so. Then again for $50 you could get two standard ones, but then again you run a risk of wearing out your clutch cos of a sloppy fork if it snaps.
I've noticed my twinner is a bit lighter than my old three puck HD as well... altho we did change the thrust bearing to an N14 pulsar one (slightly smaller in diameter) so I don't know how much that affected it.
lol exactly gerry....will be interesting but maybe not impossible
Anything is possible Duncan, especially if you have tiny hands , maybe he has a Japanese girlfriend ? I know I couldn't fit my hands in there. I never had reason to replace it with the box in so I never tried . It wouldn't be possible with a pull clutch i wouldn't think but he has a GTST with push clutch ... so maybe ... we will see ..
i had to do this. except mine snapped at the base of the bolt so it was just the thread left in the bell housing. i used a dremel to put a nick in the top of the thread and just screwed it out. i spoke to a mechanic mate and he said it was more than likely do to it being over tightened.
i had to do it in my garage (that's where it broke). so i took the gearbox out with the car jacked up about a foot off the ground. took me about 2 hours to get the box out by myself (with not the greatest selection of tools) and only about an hour to get it back in since i didn't have to keep sliding in and out from under the car cause i already had the tools there.
only cost me 90cents to fix though.
    • Followed ☺️ Assuming those are NEO rods, then at least 400kW all day.
    • Lets keep this going , Spotted this very stock V35 in Penrith and also saw a nice R32 FLY past me on Castlereagh rd , sounded really good.
    • Great work! Give it a clean up with some Emery paper, and I'd run a thread die over the threads too to clean them up. It will make reinstall much easier, and also life easier for the next time it needs to come out.
    • I'm not a fan of high humidity, it's one reason I don't mind being further inland out Ipswich, except the last 3 odd years, the drought broke, and it won't stop raining, which is making the humidity nearly unbearable when the rains are in during summer! For me, my body hates the cold, once the cold sets into my body, I'm totally screwed. I end up with severe muscle spasm in my back/shoulder muscles, and it feels like someone is trying to tear the muscles out. I have no issues with it getting stupid hot, so long as the humidity goes away. So the last 3 years as above, have been woeful! Ha ha. However, June 1st, and I'm only just converting from shorts and a tee, to long pants and a t shirt. And that's mainly as it's a bit wet and miserable and I wanted to work on a car.
    • I much prefer colder weather to hot weather, and especially prefer cold to hot and humid, Goulburn does gets pretty warm in the hotter months, but, I've found the humidity there is not as painful as even Sydney, the humidity up north is to oppressing for this old rooster  In saying this, it does get rather "nippy" in Goulburn for early morning, late in the evening walks, but nothing that a layer or two, some thermal gloves, and a beanie doesn't fix to make it an enjoyable experience, which is much more bearable to me than the oppression of heat and humidity,  especially at night when your trying to sleep If I recall correctly, a "wise man" once said that the "Southern Tablelands" was gods country, and I will not argue that point with him for the fear of a "permaban" LOL In car part related news: My intake is currently in Botany getting processed for the last leg of its shipping journey to my door
