Hey guys I got a 96 S2 Gtst
Just got a Turbosmart supersonic bov and adapter and all was going good for a couple days...
Then just tonight i gave it a few revs standing still n noticed to the revs droped a lil bit lower than usaul then sometimes when i take off then netrual it till i stop it stalls? I have played around with the tension of the Bov as it says to do so but cant seem to find the right spot for it. I dont understand why it doing it now, was ok last couple of days, any thoughts?
Thanks
https://www.sau.com.au/forums/topic/186491-new-bov-troubles/
it happened to me when i got my turbosmart type 2 veeport blowoff valve.
no matter how hard you get the tension it will keep stalling.
if you have a stock computer,then thats the reason it stalls cause the bov vents and the computer is only tuned for the stock bov which re-circulates it.
i ended up putting my stock one back on and no more stalling or you could get a good ecu $1500 and get it tuned for it.
I dont know if you want to stall in the middle of an intersection with a huge semi-trailer heading straight towards you...
Or on a freeway...
Is ur life worth a little "vroom choo?"
One of our family friend died because of that (in his brand new manual Audi, left his wife and children....)
It only stalls when i stop sharply, after ive bin driving for a long time. eg, i went out for a spin last night for a couple hours, all goin good.. then went for sum maccas, pulled into drive thru braked put foot on clutch then stall. then had a lil trouble wif idle, then when back on road again all good.
You do point out a good note thought.
Thats no good jimmytim, sorry to hear that.
Edited by Krimz
All is good now, I made a new gasket for the BOV and sealed it with some gasket goo also, and thorughly cleaned out throtle body etc. Running better than ever now :) Iv tried so hard to make it stall but all is good, and no idle troubles.
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
