Ok I recently became a victim of the dreaded cracked DBA 4000 rotor club. Wasn’t overly impressed as they were near new. But with the rotors on the bench and inspecting the rotors with DBA it appears as though there could be a fault with the caliper and the use of the rotor…combined with the fact they were used for a hard stop from over 200km/h when cold at an airport run.
So looking at the rotor the outside face (the side that cracked) has obviously run hotter then the inside face. This is evident by the blue hue in the rotor face as well as the paint markings on the outside of the rotor where two of the three thermal paint stripes have been completely burnt off. All whilst the inside face is only on the middle temp paint with all three stripes still being visible and a shiny silver as you would expect.
So, differential expansion as a result of a big temperature gradient hasn’t helped these rotors. Combined with the big hit of heat when cold. The rotors are off for some more testing and inspection. Will post up the feedback when I get it.
But some things we all may want to check. Make sure your pistons are not dragging the pads on the rotor. This is a possibility in my application even though the calipers have been rebuilt. Perhaps where was a bit if run out (doubt it) or the design of thw wheel limits airflow to the outer face (doubt it) Most likely pistons rubbing the pad on the rotor a little, or when I jump on the brakes the outer pad works a lot harder then the inner pistons.
Now finally, especially since its been a buzz topic lately. Be careful if you are going to be running brake ducts. I trialled some ages ago but took them off because I was not happy with them, and decided I would wait and do it properly when i get my new Brembos on. But if you are running DIY ducting ensure that the ducting is directed the centre of the rotor and the air then travels up through the vanes of the rotor. Simply ducting it towards the inner edge could lead to one side of the rotor (inner) running cooler then the outer face. This gives rise to differential expansion which is a known problem for stressing steel components. The main reason I removed my ducts was that I wasn’t satisfied that in the wet they woudlnt be guiding water/mist onto the inner edge causing massive temperature differentials and thermal shock to the rotor. I had not really considered that air itself could have resulted in a 200degC temperature differential across the rotor.
https://www.sau.com.au/forums/topic/186532-are-you-cracking-dba-rotors/
  • Replies 177
Posted Images
Yeh at the QR sprints very few seem to warm their brakes up at the start of the first lap, gives the transmission a chance to warm up a bit too if you take it easy for the first half lap or so.
I would be curious to see whther anyone has had their DBA4000 rotor crack from anywhere other than the small slots on the outside of the rotor.
Thats exactly what i told the guy when speaking to him . They are introducing a point of failure by running the slot to the outer edge. I dont see Alcon/AP/Brembp/Performance Friction etc etc doing that sort of slot arrangment on their street or competition rotors. My old set of DBA 4000 which lasted an eternity had the old slot design as well, (ie no little slot on outer edge)
Here are a couple I prepared earlier.
I was not running any ducting & the stone guards were in place. Rotors cracked on the outside.
Note the rear failed completely & if you have a look at the front you can see the start of a crack propogating from the small slot.
I don't think you need look any further than those slots to see what kills these rotors. Note that there was minimal wear on all of them, pads were RB74's & they got a bit warm as you can tell by the surface of the rotor.
I have another dead one at home (a front) that is cracked through from the return slot.....If you have the ear of anyone at DBA tell them to bin the return slots.
I will dig up my crack....far, far , far worse then those. And it took no time at all to propogate into the hub.
Makes me wonder why DBA are only doing a limited run of these, curved vane with Alcon style slots.
UAS have some for sale at the moment. If i didnt have the Brembos then i would grab some :thumbsup:
yes they are shit. there is to much chrome in the iron. we crack them every 2 race meeting. (v8 utes) they seriously are shit. end of story. they lasted longer with no ducting. no point blowing air on the inside when theres no flow on the outside. this creates unevan expansion and pop. they crack at the slots. usualy all of them. bloody rules...
Environment: DBA4000s, DS2500s, MBF600, backing plates, UAS 324mm kit
Roy, i have the same problem with cooking the outside face of the rotor only. I also assumed it was stuck/dragging pistons and rebuilt the front calipers last weekend. I hope that wasn't a waste of time! Anyway, i'm going to Wakefield on the 8th for some 'testing'.
I also noticed that it was a bit patchy and appeared worse between the 'vanes'. Perhaps the inside face of the rotor is pulling heat across from the outside face, thus cooling the area at the vanes better that the air in the between the vanes does. I should have taken a photo before sanding it off....
Its hard to see how this could happen unless the inner pistons are stuck. Force = fluid pressure x area, which is the same on both sides.
I would guess the curved vanes provide more surface area and better fluid flow, so better cooling.
Maybe the limited run is a beta test?
as for the alcon slots? marketing.
They're also copying what appears to be a better design - alcon thought well about stress concentration.
I hope they give up on the bloody "wiper slot" and "kangaroo paw" bullshit and keep making those curved vane one with the alcon style slots (or even normal slots).
yeh i get that but there is that part of me that thinks that because i run teh adpator brackets for the larger rotors that perhaps the caliper is slightly offset a mm or two?!?! So when you jump on the brakes that the rotor is being distorted and compressed against an off centre caliper.
I'm not sure if the calipers being slightly off-set would or should be a prob, as long as they are still running square to the rotor. With all pistons sharing the same fluid circuit per caliper they should "sort themselves out" for want of a better term & simply travel as far as required per side/pad to deliver equal pressure to both sides of the rotor.
Also in regards to pad drag on the rotors, my Brembo 8's actually have springs fitted behind the pistons which acts to both minimise knock-off & provide just enough contact to build & keep enough temp in the pads & rotors that initial bite & thermal shock is never an issue. This allows me to run Hawk HT-10 compound pads with a temp window of 149 C - 871 C as a street pad with no issues or "oh f**k" moments. Literally takes less than 2k's of driving from dead cold to have usable heat with NO application to help it on it's way.
It's obviously a different story if only one side of the caliper is dragging though........
Would there be any noticeable pad wear from this? Obviously if there is friction to build up heat then it's wearing the pad (even if just slightly, its 100% of the time!). How quickly do you go through pads?
Mate to be honest I've only done a few thousand k's on this setup & I haven't had the pads out to take a look but once I do I'll post up the info.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
