Oh o.
I have just put DBA 4000's on the front and rear with Hawk HT-10's front and rear. Might have to keep an eye on them. They cooked the fluid fisrst time at the track but thats my fault for not flushing and changing the fluid with some good stuff. So what does the paint on the rotor tell me. So the set up is a R32 GTSt with UAS adapter plate to run DBA 4000 GTR rotors with Hawk pads.
Cheers
  • Replies 177
Posted Images
Gary from what I've seen the difference is simple.
slotted DBA 4000 crack.
unslotted 4000 and any 5000 series seem to be OK, I'm sure there are differences in design that is making the difference. there have been waaaay too many slotted 4000s crack in the last 18 months to be coincidence and dba are doing their business real damage in the enthusiast market by ignoring and denying the problem.
Interesting read.
I'm in the process of upgrading my brakes and was thinking, RDA or DBA slotted rotors front and rear, QFM KR750 pads, and braided lines all round.
Now having read all of this it sounds like thats a bad idea as they're just going to crack....So my question is, what options are available to me? Doesn't seem to be many...
Car is a S2 R33 GTS-T, 250~rwkw, daily driven so need a pad that will work on the street as well as take some track work.
  • 4 weeks later...
they claim they are 'heat treated' I'll give them some fking heat treating. my next set will be project mu or endless. I have a new set of RDA sitting here and will give them a crack but I'm not putting too much hope out there.
+1 for endless, running their slotted disc with my ap's and they love the abuse :down:
You could be right, I am still using the 4000 series rear rotors that are at least 3 years old, compared to the third set of front rotors but they are 5000 series. Maybe the newer 4000's are the problem.
Cheers
Gary
  • 3 weeks later...
Ok I recently became a victim of the dreaded cracked DBA 4000 rotor club. Wasn't overly impressed as they were near new. But with the rotors on the bench and inspecting the rotors with DBA it appears as though there could be a fault with the caliper and the use of the rotor…combined with the fact they were used for a hard stop from over 200km/h when cold at an airport run.
So looking at the rotor the outside face (the side that cracked) has obviously run hotter then the inside face. This is evident by the blue hue in the rotor face as well as the paint markings on the outside of the rotor where two of the three thermal paint stripes have been completely burnt off. All whilst the inside face is only on the middle temp paint with all three stripes still being visible and a shiny silver as you would expect.
So, differential expansion as a result of a big temperature gradient hasn't helped these rotors. Combined with the big hit of heat when cold. The rotors are off for some more testing and inspection. Will post up the feedback when I get it.
But some things we all may want to check. Make sure your pistons are not dragging the pads on the rotor. This is a possibility in my application even though the calipers have been rebuilt. Perhaps where was a bit if run out (doubt it) or the design of thw wheel limits airflow to the outer face (doubt it) Most likely pistons rubbing the pad on the rotor a little, or when I jump on the brakes the outer pad works a lot harder then the inner pistons.
Now finally, especially since its been a buzz topic lately. Be careful if you are going to be running brake ducts. I trialled some ages ago but took them off because I was not happy with them, and decided I would wait and do it properly when i get my new Brembos on. But if you are running DIY ducting ensure that the ducting is directed the centre of the rotor and the air then travels up through the vanes of the rotor. Simply ducting it towards the inner edge could lead to one side of the rotor (inner) running cooler then the outer face. This gives rise to differential expansion which is a known problem for stressing steel components. The main reason I removed my ducts was that I wasn't satisfied that in the wet they woudlnt be guiding water/mist onto the inner edge causing massive temperature differentials and thermal shock to the rotor. I had not really considered that air itself could have resulted in a 200degC temperature differential across the rotor.
Hi,
I've been reading all these posts with great interest up to page 4-5.
I'm due for front rotors soon and yes, learning along the way, I've decided to go for G4 or DBA5000 where the slots don't go up to the edge
Two Reasons
1) Being a chemist, I've noticed that tablets that are scored (ie slotted) across the middle are harder to break if the score doesn't reach the edge and
2) Having cut glass for leadlight many times, it's much easier to break the glass if I start the glasscutter from right over the burr of the edge - meaning it's hard to snap the glass panel unless I start from right at the edge.
Therefore the newer DBA4000 rotors are simply a very bad design - and they'll need to change it quick.
As they say in business: it takes 10 years to build up trust - and 10 minutes to lose it!!!
Chow
Hi,
Two Reasons
Chow
It's catch 22 with slots. If you don't take them to the edge, then they simply don't work as well in their wiping function. The trapped gas and loose material can't escape the slot, so it builds up under the outermost portion of the pad (the outer end of the slot). This decreases the braking performance and causes uneven pad wear.
Cheers
Gary
Cheers
Gary
The G4 kit doesnt take the pad all the way to the edge, so it should avoid that problem. Also the radial direction of the DBA4000 slot seems to contribute to the stress build up. On other designs the slots are about 45 degrees to the tangent, rather than being almost 90 degrees.
Hi,
Just got a price on getting some blank DBA heat treated rotors (4000's????) and getting SCBC to machine some wiper slots in them more like the project mu's for $630.00 a pair to suit the front 324mm brembos.
Do you think these will have a greater chance of not cracking or is the cast metal just not up to the task of hard braking?
Cheers,
Ryan
Hi,
Cheers,
Ryan
Well to be perfectly honest for the amount of messing about & the cost - why don't you just import some Project Mu rotors & be done with it?
As has been said it is not believed to be a metallurgical problem moreso a problem derived from the use of the small return slots around the outer circumference of the rotor.
Well that is some good news. The Stoptech gear certainly move some air through the rotors.
Not exactly light weight, however.
But the big question is: How much?
The one disappointment of the Priject Mu 2 piece was the lack of proper vanes, although they are better in that regard that the DBA gear.
I can add my same experiences to this thread too.
I cracked 2 sets of 296 Dba's before I went to 324mm on the front of my 32GTR.
I have now cracked my second set of 324s. After cracking the first set, I ran ducting to the centre of the disks, and still cracked the disks.
So.... DJR81 like you I'm swaying towards the Project Mu's. How have you found them ?
And more importantly have you run them at barbagello more than once ? I can get a year of sprints out of a set of disks, but as soon as i take them to a long circuit where braking from a high speed is involved, they crack, (from the slots in the 4000's.)
Stoptechs are a second thought, but they seem to be about twice the price ?
The most annoying thing is, that if i had not given dba the benefit of the doubt I could have saved a lot of money or upgraded seriously with the same dollar amounts i have wasted.
Anyone else using Project Mu's ?? or will i crack them too ?
Got some advise regarding cracking/crazing rotors from a brake joint in Penrith.
He said that cryogenically treating them makes them less likely to go to crap out, but it doesn't make them last longer.
Might try it out on the next set of rotors.
    • If you have the original log book and it didn't have a chassis number quoted, then no money required.  I have "rechassied" a number of race cars, no problem as long as you have the original log book.   Cheers Gary
    • Well the good news is that it won't run any worse with an atmo bov than it does with no bov, I've owned a few Nissans over the years (r32, s15 and now r33), the stalling issue caused by a bov or no bov while still having an afm is easy enough to live with, most people get used to driving them and just feathering the throttle when you come to a stop to avoid it stalling. Changing to a proper ecu with a map sensor is ideal but in the short term I'd just slap in the bov if you really want the whoosh sound. I looked into the pass through type maf like the R35 one above but decided against it as the amount of oil and crap flowing through the hot side would mean you'd have to clean it often to keep it working.
    • Build an 800hp motor. Make it as bullet proof as you want, you WILL still break things. Like, the rest of the car. Heck, even as a dead stock car, things will still break, but the more power, the more everything else will let go easier. From gearbox gear sets, to extra stress on the chassis/mounts, more stress on diff, axles, tailshaft, even the suspension mounts. Check out the motorsport build that last year went to a Bosch motor sport ABS setup, and now can brake so damn hard it's twisting mounts for suspension/subframe etc. Now if the brakes can do it, imagine what happens with super grippy tyres and 800hp in a low gear...   Shit, I'm presently out fixing the girlfriends daily driver that rarely sees past 3,000rpm and is used to cart the dogs around in. Everything WILL break. If you don't want it to break, don't drive it. And then laugh, as it will still break without even being driven!
    • ECUMaster is an Australian company from memory, been around a while, and seem to actually play really well on more unique engine setups. Seems to be more of them being used in the states, and they seem to support more cylinders than most others.   My opinion on stock ECU/Nistune with he AFM, is you can tune around the issue of stalling. It's still a bit of a band-aid, and not the most perfect smoothest setup, but it can make it drive able and not an absolute PITA. But you're still compromising. A vent to atmosphere BOV has the same issue as no BOV with regards to the AFM. Both make the ECU think more air is entering the engine than there really is. And I can't find any hard science/decent evidence that supports the claims all the "you MUST run a BOV of some sort of you'll blow the turbo up". About the only one some people can give of why is "lag between gear shifts", and that is only an issue when your boost source for the waste gate is pre throttle body. I ran my boost source for the TD07S off the inlet manifold. Didn't have weird boost spiking issues, didn't have boost control issues, and on a gear shift the wastegate slammed shut, which meant all exhaust gases would be keeping it going round and round and not waiting for the wastegate to shut again when I stepped off the clutch and back on the loud pedal. It came back on boost in the next gear pretty much instantly.   ECU / tune / BOV choice I think really comes down to a lot more factors than just what you've stated. And personally, especially for daily driving, recirc setup for the BOV, or no BOV. I dislike the really loud BOV when everyone is taking off from the lights etc.
