Has anyone run a twin exhaust on there 33? not on the same side running one to the left hand side and one to the right?
Is there enough room down the right hand side to run it?
At the moment i have a 3inch stainless steel exhaust so i thiugh of joining in after the cat to run another 3inch pipe to the right, but unsure if theres room.
and i only wanna do it for looks
https://www.sau.com.au/forums/topic/186534-twin-exhaust/
yeah i've done it, it's a mission but.... got it sittin at home cause i pulled it off as it was heating up the boot pan too much and has some clearance issues when going over big bumps but it is possible
oh ok nice.. do you have any pics of what it looked lik?
https://www.sau.com.au/forums/topic/186534-twin-exhaust/#findComment-3371735
brilliant.
why not buy a cannon muffler, and cable tie it to the other side of the rear of the whale?
ALA Corolla's and civics bro.
then you got da looks and not da cost.
good izdz. but wat about running two cannons next to eachother? kits available. increases midrange torque.
dont worry about gtst man, just ignore him he never says anything positive.
https://www.sau.com.au/forums/topic/186534-twin-exhaust/#findComment-3374906
Can you explain how that would increase midrange torque?
https://www.sau.com.au/forums/topic/186534-twin-exhaust/#findComment-3375165
Im interested in the response to that aswell.
I dare say the answer will be 'interesting' :sorcerer:
But yeah, as GTS-T said.
Just put another muffler on the side if you want looks. No point hooking up pipe to it all as it wont offer any gains, add weight, and cause the car to be low and hard to get over speed humps etc.
So just get the angle grinder out and cable ties and then you'll have the looks
https://www.sau.com.au/forums/topic/186534-twin-exhaust/#findComment-3384198
I've got a twin exhaust, be warned though that it's neither cheap nor easy to do. Mine is 3" to the diff where it splits to 2 x 2.5". I've made modifications to both the rear bar and the spare wheel carrier to make it fit properly. The exhaust work was done by Mercury Motorsport in Brisbane.
https://www.sau.com.au/forums/topic/186534-twin-exhaust/#findComment-3384731
Hey man.. don't be so negative. :(
it will produce more midrange torque due to the way it's designed.
because there are 2 pipes it means more money was spent.
this in turn leads to lighter wallet, a feeling of stupidity, and a the need to lie about it to people you don't know on the internet.
therefore, applying the formula:
need2Bdifferent + feelinstupiddue2xtracost = need2lie2intraweb.
this forumula then manifests itself in to the theory we call "thefirstbullshitreasonyoucancumupwith"
Therefore, twin exhausts = increase in midrange torque.
You should know this man..
Edited by GTST
https://www.sau.com.au/forums/topic/186534-twin-exhaust/#findComment-3384804
Hey man.. don't be so negative. :dry:
skoold'
https://www.sau.com.au/forums/topic/186534-twin-exhaust/#findComment-3385109
gold
https://www.sau.com.au/forums/topic/186534-twin-exhaust/#findComment-3385160
This Thread is a prime example of why each skyline state needs a fight club meet every 1/4 or in laymens terms every three months. So everyone who goes on the cruise to enjoy their cars and other peoples cars also has an option at the end of the cruise to enter "The Ring Of Internet Heros".
So at the last meet point theres a ring set up and who ever has gripes or what not deals with it once and for all. The loser gets to shut the f**k up.
Thus ending the needless (countless) communications and clogging up SAU forums. So put down your keyboards and raise ya fist's and do it the old fashion way.
+1 :dry:
https://www.sau.com.au/forums/topic/186534-twin-exhaust/#findComment-3385186
+1 :dry:
Wow this has taken a turn i wasnt expecting.... All i wanted was a few pics of what the twin exhaust looked like... the veilside was a great example, love the look of that....
People want different things out of there cars, i wouldnt have a go at you GTST what ever you wanted to do to your car, even if i thought it was a bad idea... Why you have to come into peoples thread and say stupid s**t all the time is beyond me. dont you have anything better to do? You worry about your car and ill worry about mine, cos at the end of the day ill forget everything yopu have said and only take in advive from the people who know what there talking about
https://www.sau.com.au/forums/topic/186534-twin-exhaust/#findComment-3385251
I thought it was a stupid idea..
people are so f**king sensitive these days.
you didn't like that I didn't think you had a good idea?
Go have a cry emokid!!
for f*ks sake
+1 for meetup beatings.
https://www.sau.com.au/forums/topic/186534-twin-exhaust/#findComment-3386556
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
