  • Replies 86
Posted Images
Did you hear this directly from Dean/Alisa/Cabin?
I would highly doubt for the biggest show in their calendar, they would be capping cars.
They havent in the past, and are always down on the max number of entries. They have not had a 100% full show in years.
If they capped cars it would annoy quite a number of long-time supporters like Elite, SAU, NS.com, Agentz and so on.
your missing my point here,
Yes it came direct from Alisa and the manager himself and also the VICTORIAN Rep!! they will take more then 10 if they are all highly modded!! they wont take more then 10 if a large % of them are too stock! i'm just lettin ya know what the organisers themselve told me, and a few other car clubs... if your going to enter so many i suggest calling Alisa First!
if all your cars are modded you will be fine but if you are trying to kill it with numbers it wont work...
i'm sure Elite, NS.com, Agentz dont enter a shit lode of plane street cars so of corse they would be fine.....
I've spoken to Alisa and got the ok for our number of cars. Because we have a combined display with SAU and FangArtists we are allowed more than 10 cars. This has always been the case with SAU.
If an individual club display has more than 10 cars, the extra cars will be assessed on merit.
I think we're safe but thanks for the concern.
    • Nope. The seal is in the drive. A new cable would just fill up and continue to convey oil to the speedo head. To check if this is what is happening, take the cluster out, dismantle the speedo and have a look. You probably don't even have to dismantle it. If there is oil coming up the cable, the drive into the speedo will be grossly greasy. I had to manually (and delicately) clean the gunk out of my speedo.
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
    • OK...so dumb question to check....do the hi beams actually come on when the push the stalk to engage them (keeping in mind your headlight switch must be at ON as well)
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
