i got one from regency a while ago but dont know if they have em anymore.... contact motor reg department and see if they can point you in the right direction, they usually have info for anything motor related
https://www.sau.com.au/forums/topic/186604-defected/page/2/#findComment-3376234
i only got the pod filter secured on a bracket a few weeks ago when i got my turbo put in to avoid gettn defected for it. all the mods on my car are very hidden including the power fc unit. the cop couldnt find anything hence why he defected me for bullsh*t mods.
i am going to make an official complaint, ive got the sheet. I had my mate with me so he can back me up with what happened.
but it's true some cops pull me over to check if the car stolen and then they would usually say 'nice car' or something friendly, but unfortuantly i got an arsehole.
It sucks that Skylines are being targeted, but basically your defectable car got defected, and you're going to complain because they defected you for the wrong things?
Let us know how that goes.
https://www.sau.com.au/forums/topic/186604-defected/page/2/#findComment-3376636
Unfortunatley it is the sad truth that the police can pull you over for no reason and slap a defect on your car.
It does not even have to be defectable it is only in the opinion of the police officer to be defectable.
Everytime we drive our cars on the road we are taking the risk of being defected and especially if you have been defected before and are in the system. :(
https://www.sau.com.au/forums/topic/186604-defected/page/2/#findComment-3378070
It's not about empathy, I feel he is going to end up making the situation worse for himself, rather than better.
Also your contribution since arriving here is far from positive for the skyline community zamels - "OMG MY CAR RATTLEZ AT 260 IZ IT NORMAL?".
https://www.sau.com.au/forums/topic/186604-defected/page/2/#findComment-3378074
like Carl said Elliot, be careful with your words when writing a complaint to the porks.
Most complaint matters of this regard would usually get tossed and put through the shredder without the complaints advocate even taking any action to investigate it. and when you go to chase them up and try and push them into some action desicion making with the complaint, they will reject your request, and just make you line up and go through the system (ie vehicle inspection) like everybody else.
Believe me, i tried mate!
but good luck though.
Anything can happen if things get in the hands of the right or wrong person working within the transport arm of SAPOL.
https://www.sau.com.au/forums/topic/186604-defected/page/2/#findComment-3378317
One of my mates that had been defected a few weeks ago were in the car, he was explaining that an internal wastegate was needed, but the pig said to us if we say anything else he'll book me for something else.
i was coming down milne road toward mcintyre road, he was behind me on milne but decided to follow me then pull me over down the bottom of mcintyre.
i went to the cop shop right after it happened i gota a blank stare from the stupid bitch at the counter, so i just said get me a complaint notice. Im just really pissed coz my car will be off the road for ages while i source stock suspension, airbox, take out power fc, avc-r, turbo....ect.
Don't forget the injectors (and you'll have to source some standard ones cause the standard ecu won't run the 550cc's), some standard suspension etc etc.......
https://www.sau.com.au/forums/topic/186604-defected/page/2/#findComment-3379345
nice empathy, tool
Apparently i have a friend lol. Im aware that my car was defectable, but it is annoying when you put so much money and time into making the car inconspicuous and you get pinned.
im not stupid either im aware that sapol are very closed ranks and that any attempt to attack a police officer would be a one sided affair. i can be tactful while alerting them to the problem
https://www.sau.com.au/forums/topic/186604-defected/page/2/#findComment-3379355
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
