I have searched but couldn't really come up with much info except the Motul seems to be really good.
However, one workshop reccomends the AP Racing even though it has lower boiling temps than the Motul because APPARENTLY, the Motul's can overheat easily, especially after a few hard laps on track.
Also, just wondering if they give good pedal feel ie. firm feel when braking.
Thanks in advance.
I used to pay $$11ty for the Castrol SRF and after a while I got over paying that much so I tried the Motul RBF600.
I can't say I have noticed any difference between the 2 and can't fault the RBF600 at all. I really don't see why people would pay more for a brake fluid when that stuff does the job perfectly.
I've used both AP 600 and Motul 600, both are good and never found a problem with sprint races upto 15laps in 1200kg GTSt or 1550kg GTR.
AP is $55 locally and Motul is $25... I now only use Motul for obvious reasons!
If you want the Motul fluid the best places to go looking are the motorbike shops. For some reason they carry Motul gear.
Also it is dot 4 (600) Which means it is much better than the run of the mill dot 4 fluid. The 600 is its boiling point in degrees fahrenheit.
Stuff paying $55 for 500ml.
Someone will be along in a minute to tell you about the Penzoil gear.
Edited by djr81
In Australia Motul has primarily been a bike brand... only in the last 5-6 years has it been pushed to cars.
Link International used to sponsor my Skyline when they were promoting the expansion.
Its always been big in Europe for both cars and bikes though.
yes, pretty funny. have a look at the bottle. ap,motul,penrite. sanme bottle. just differant lable and colour. all the same in my book. srf is just spastic expencive. we noticed no differance in the utes. (tested back to back)
we melt pistons in the calipers before it boils the penrite stuff.
motul rbf 600 is a DOT 4 only fully synthitic
motul DOT 5.1 is dot 5.1
im useing the dot 5.1 in the r31 and useing it at track days and it good
Why would you use the 5.1?
Brake Fluid..............Dry Boiling Point................Wet Boiling Point
Motul RBF 600..................593°F...............................420°F
Motul DOT 5.1..................509°F...............................365°F
Edited by djr81
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
