  • Replies 138
is the response is pretty good? full boost by XXXXrpm?
Good power for low boost to :(
im pretty sure i had full boost by 3500 rpm, but i have to check it out again. was raining last night and i had to drive like a gran.
And thanks :(
well done mate :worship:
my guess was 251.2rwkw
so thats what i wanna see on 16psi...................right !?!?!? :(
and yes, i believe you'll have no problems with the new bov. GFB bovs are very decent.
a gtr bov probably would have done the job too.
Edited by Munkyb0y
im sure i can do it.
and thanks :)
Hey guys finally im ready to finish off my car. really anxious!! Existing mods on my r33 gtst which i made 209rwk
-pfc
-blitz fmic
-ebc
-sliding performance hiflow turbo (non vg30 rear)
-3in turbo back exhaust w hiflow cat
-k@n pod
-stock fuel pump
-stock afm
-stock injectors
-ran 13psi
new mods and retune with these extras
-tomei intank fuel pump
-z32afm
-500cc hiflowed injectors
-hks actuator
-going to run 17psi
what will the final figure be? Take a guess.
Question....who did the highflowing of your injectors???
Depends how happy the dyno is.
I would say between 230 to 250 rwkws....
Whats the prize anyway......do we get to eat the smarties in the jar :)
I won the smarties.... :)
240kws...smack in the middle
quick question guys. i just finished installing the new bov and it keeps stalling when i clutch in as im slowing down in 2nd.
ive tightened it up and it just makes the psssh noise. dosent "flutter" anymore...
did u plumb it back? or leave it atmo?
atmo will give you issues alot of the time. it did on mine to a degree. occasianally stalled, idle was a bit tempremental, and the psshhht gave me the shits.
i plumbed it back, no more problems.
edit: i've got the GFB hybrid bov
Edited by Munkyb0y
i plumbed it back
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
