i cant stand the atmo bov. im going back to the stock one. is there anyway i can make it hold boost better?
i cant remember where i saw it in a thread but isnt there a little breather hole...should i block it up?
Edited by R33GOD
  • Replies 138
Yeah take it off and block off that little hole.
And to make it hold even more, "adjust" up the spring tension by crushing the top of the bov in a vice. too crush it even more, tap in the top too a rounded bowl shape. It'll be super tight now, and will be able too hold your desired boost.
This is the hole to block. Use a screw/tape/hot glue/whatever.
It can be crushed to about this height. It'll collapse in it's proper order, just let the vice do its work.
Tap it on the top and round it inwards for even more tension.
You may experience flutter under certain conditions. Usually only under light throttle back offs when under boost.
I just crushed it till I felt it stop. I don't know if you can get solder to stick to cast. I used some tape folded over a couple of times.
You'll feel it when it can't crush anymore. The nipple will touch or bottom out and may bend a little.
Edited by KeyMaker
im gonna try n find something to block the hole off now and use my uncles vice tomorow and put it all back together. is there any downside to this or should i be all good?
Just make sure whatever you use isn't going to get sucked/pushed through.
Use a piece of wood with the vice to crush it.
You can use a ball pein hammer or a hammer and shifter to round the top in.
The only negatives could be the flutter that everyone argue's about. It only happens when you back off the throttle lightly when under boost. Gear changes and sudden back offs it functions normally.
It flutters under that condition because of the tighter spring tension, and the vacuum isn't able to pull the diaphragm up. Any aftermarket BOV does pretty much the same thing anyway.
Edited by KeyMaker
i tried the fan case screw. the actual thread is not tight in the hole but the head of the screw fits perfect. what i dont was put teflon around the screw and put thread locker just underneath the head of the screw. if that dosent work il try somthing else
I've came across a few different sized case fan screws.
These are the type I used - http://www.pccasegear.com/category83_1.htm
Unsure if they are identical to the ones I have but thats what they look like.
They were very difficult to screw in as it was very tight they were also super tight when screwing in to a computer case fan.
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
