it won't fit in a million years :P
I have tried it. the rail is nearly twice as high than the side feed rail with the injectors fitted and it will not fit under the plenum. also none of the bolt holes line up.
i even looked at modifying it but there is just no way.
  • 3 weeks later...
RB20 fuel rail WILL fit onto RB25DET. All that needs doing is to machine up 6x adaptor rings for the injector base seals, and to weld new mounts onto the fuel rail.
And it WILL fit under a standard side-facing plenum chamber quite nicely.
Then GTR injectors etc can be used on RB25DET. A resistor pack from a GTR will be needed, or just wire in individual resistors. (Cost me $1.40 for each resistor).
    • Hi all, I’m currently running a str pipe hi low hks exhaust and downpipe. Was wondering if I change out muffler to a titanium one will it change the sound of the exhaust? Plus I have always liked the look of the titanium pipes … anyone have recommendations to one?    side note already have titanium intake pipes.
    • I looked up my other car that is a R33 GTST series 1.5. Anyone able to confirm what a Aero Form Bumper is?     (1G) 2 Door Coupe; (2GK + 11V) RB25DET; (4B) 2WD HICAS; (7F) 5 Speed Manual; (14G) Super Fine Hard Coat; (15U) Large Rear Spoiler + Aero Form Bumper + Rear Wiper (Aero Selection)
    • Ha ha, all good! I've almost caved in and realised I'm buying one.  I know myself well enough by now that I will start chasing ADHD butterflies half way through building it and not finish it so I'm better off spending the extra money buying one instead of making one just so I can get into straight away.  I would very much enjoy making one as fabrication is probably a strength and definitely a passion but I don't want that to be at the detriment to the car I'm ultimately building it for! There's some pretty good ones around for ~$1100 at the moment so I think I'll just go that way.  At the end I sell it or as mentioned, get another project to make further use of it! Thanks gents.
    • That link was very helpful thank you.
    • That is the option code, not the VIN. Regardless all of that production is considered series 2: https://gtr-registry.com/en-ecr33-vin-table.php
