nice, I just spec'd one up in black. with bose system and snap-on tool kit (lol, $2K for that). total's 9mil inc tax.
Gunmetal specced out, 9mil :)
oh damn it looks HOT in black
and so how do you do this?
  • Replies 148
in case you missed it:
in case you missed it, just uploaded the full press brief to youtube:
Part 1 of Nissan's Press Briefing @ TMS - 7:38 Nurburgring Lap
Part 2 of Nissan's Press Briefing @ TMS - GT-R Reveal
Part 3 of Nissan's Press Briefing @ TMS - Other Nissan Concept Cars
7:32 - Porsche Carrera GT (7:32.44)
7:44 - Zonda
7:46 - Porsche 996 GT2
7:47 - Porsche Gt3 RS (sport tyres)
7:50 - M3 CSL (sport tyres)
7:52 - GT3 (381hp)
7:52 - Lamborghini Gallardo
7:52 - Lamborghini Murcielao
7:52 - Mercedes SLR mclaren
7:56 - Porsche 996 Turbo
7:56 - 360 stradale (sport tyres)
7:57 - Lotec Porsche 993 Turbo (600 HP, racing suspension)
8:07 - Ferrari 550
8:09 - Lamborghini Diablo SV
8:09 - Ferrari 360 Modena
8:10 - Chrysler Viper GTS
8:12 - Porsche 993 Turbo (430 HP version)
8:15 - BMW Z8 400 HP
8:17 - Porsche 996 C2
8:18 - Ferrari F355
8:22 - BMW M Coupe 321 HP
8:25 - Audi RS4 375 HP
8:28 - Porsche 993 C2
8:28 - BMW M5 400 HP
8:32 - Porsche Boxster S
8:35 - BMW M3 Coupe 321 HP
8:37 - Mercedes C32 AMG
8:38 - Honda NSX
8:39 - Honda S2000
8:40 - Chevrolet Corvette
8:42 - Audi S4 265 HP
8:42 - Lotus Exige
8:49 - Jaguar XKR Coupe
8:52 - Mercedes CLK 430
geez new GTR is god damn fast!
Where does the Ferrari Enzo FIt in that List??
Watching that beast Tear around Nordschleife was awesome to see.
340km/h top speed doesnt sound Optimistic at all.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
