TT Car # Team Shake n Bake Vehicle type
895 Manion/Manion 33GTR V-spec N1 1995 Walker / Texas Ranger
979 Wooster/Kulhanek 34GTR V-spec II N1 2001 Jean Girard / Hershell
904 Millar/Dean Evo IX GSR 2006 Ricky Bobby / Cal Norton Jnr
962 Kennard/Grimwood Sti Spec C 2007 Larry Dennit, Jr. / Lucius Washington
Why? because we like to shake, then bake!
Edited by Marlin
  • Replies 369
stay off the yokos mr tom. they are rubbish which we only run because they are control tyres. expensive and far from the best.
but based on last year's experience I would say don't go the bridgestones either unless you can guarantee no rain :D
Team Release
Team “Shake n Bake” can’t wait for Targa 2008!
Thursday 27 March 2008
The social side of Targa almost outweighs the competitive side and as a bit of fun, a group of mates comprising of recent and past Targa competitors have banded together to enter the Targa Teams Section as Team “Shake n Bake”.
In the true spirit of racing these guys are hunting the 1st place 2008 Targa Team Trophy… “because if ya ain’t first, ya last!”
Team members are:
The laughs and jokes will be put aside at the start of each stage as the crews get down to business.
While the GTRs of father and son crew, Manion/ Manion and newly formed crew of Wooster/ Kulhanek are fighting it out in the Outright Modern competition, the EVO 9 of Millar/ Dean and WRX of Kennard/ Grimwood will be racing for a place in the inaugural Showroom 4WD competition.
You can rest assured that either in competition, at the end of each day and on Sunday afternoon in Hobart, Team “Shake n Bake” will be having fun and enjoying the spirit of Targa Tasmania!
“Shake n Bake baby! Why? Because we like to SHAKE… then BAKE!!!!”
Yay! piss up sunday night it is then
Sounding like a plan :banana:
I sat in the car this morning to check I fit etc and now I'm officially excited.
Only 11 days before we leave for the boat!
So does Team Shake and Bake need a offical photographer for the event ?
Im heading down to cover the event, i think a team shoot on monday would look good ?
Sounds awesome dude, ill see what the other guys think.. but its a bit of a no brainer!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
