Thanks guys. I've found a complete set of GTR Bembos, front and rear. Just gonna price up new Brembo 2-piece rotors/lines/pads. Will let you know what i decide. G4's are good value, just spoke to the boys down there but Steve wasn't there for me to lean on........ (see my sig) :P
  • Replies 369
Yeah, end of Day 1 2005 there was one sitting 13th outright. :P
GTS-t is one of the most forgiving, easy to drive fast cars you will ever sit in... I regret letting minego to that useless Rocket - just as the rules came round to suit them even more.
and to rub salt into the wound, he took a snap of us this year with the old girl in the back ground!
Not sure you will run with the RSR in the dry, but you'll hose him in the wet.
Anyhow, I'm all emmotional now...
Winton, what are you doing down there... I thought you were a Queenslander?
TT
984
What happened after day 1? :dry:
Who ended up with yours? Rocket? Do I know him?
The car is still in Melb so figured we'd drag her up to Winton for a test and flog :P
What happened after day 1? :)
The car is still in Melb so figured we'd drag her up to Winton for a test and flog :)
The 800 camera car is Gregs old car.
130i too heavy, 135i too pricey, Focus XR5T and RX8 too slow. I like the idea of DSG R32 Golf, but suspect a weight issue.
72k for a 135i coupe Stu....... whadya reckon? I'd be all over one like a rash! - if I was that way inclined :thumbsup:
