Rb30/26det Advice
PALADN
 Share
Hey guys.
I have built an RB30/26 Head.
MODS
rb30 series 2 block
rb26 head (fully reco)
PAR rods
Aries Pistons
All ARP bolts
ACL Racing Bearings
Race preped crank
High Energy 8.5Lt sump
Knock Sensors Moved higher on the block
Nismo Twin Plate
After Market Smaller Balencer
870cc Injectors
Jun Oil pump
Jun Drive Collar
External Oil return (back of head to sump)
Thickest Cometic metal head gasket (recommened by rocket to use with the aries pistons??)
High mount manafold
Garret GT3071R
Surge tank with 044
After market fuel rail
After market pressure reg
Link G2 ecu (with air inlet temp sensor)
I think thats everything
Ok heres my problem
The engine has been having oiling issues since it was built. we first installed a tomie oil kit into the block with no luck. It still poored oil into the catch can at mid to high rpm. We then pulled the head off and blocked off the rear oil feed. Seamed to work better but still puts oil into the catch can. Part of the issue is that when hot the oil pressure sits at around 25-35psi at idle but any touch of the rpm and it jumps to 100psi.
Does anyone have any sugestions? I was thinking of some how turning the pump pressure down??? is this easy to do? if so how?
Just as a side note the engine made 230Rwkw and 560Nm torque on 13psi
Also anyone got any sugestions on a new turbo? cant be to lagy
Edited by PALADN
have you looked at our oil controll thread by Sydney Kid ?
Did you run a oil return line from the back of the head to the sump?
did you make the oil return holes bigger to the sump ?
did you change the baffles and go for some after market ones?
Im hoping you forgot to put the crank collar in your list of mods, or youll be looking at more than a sump off job soon. Do you know what bearing clearances you are running, tight clearances increase oil pressure.
Edited by Adriano
hi mate,to drop pressure in an oil pump you need either a weaker relief spring or the same tension spring but shorter in length.. the sump must be removed then you can see the oil pump relief nut, undo that and a spring and plunger fall out. then its a new spring and away you go.
Edited by rockabilly
 Share
    • Unless there's something particular about the Greddy manifold's injector holes that I'm not aware of, those injetcors look to be totally wrong. They would absolutely want to be spaced up to get those long snouts out of the runner. Which, I think, is not usually the way that that problem is solved. I think the problem is solved by using the correct injectors, which would be much more like what Andrew posted.
    • Thanks for the reply, So i've continued playing around, and fitted the injector adaptors onto the injector, the fuel rail is not able to be mounted now as the injectors sit a bit further out. I suppose the point of the adaptors is so that the injector nozzle isn't so deep into the intake? I suppose 1mm extra on the o-ring would do it but still can't mount the rail onto the intake haha. Waiting on a reply from Aeroflow I'm sure there's something stupid that I'm missing...
    • EMJ33 or EJM33 - west end
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
