This vehicle will come with rego until April 2008 + roadworthy certificate.
Newly complianced.
This is a private sale, genuine reason for sale.
The Caldina is an AWD wagon, with the most powerful production 3SGTE Toyota ever made.
Stock standard the manual has 193kW with 324Nm of torque and weighs in at 1360kg (not too bad for a wagon!).
Performance figures are quoted as:
0-100 in ~ 6 seconds
1/4 mile in 13.9secs.
Yet this car uses 9L/100km (10-15 mode city driving), and I've managed under 8 while highway driving.
This car also has Vehicle Stability Control for great handling, a rear LSD and of course ABS, Airbags, power everything and HID/Xenon headlights.
This is a very well cared for example, it was an auction grade 4 and I have all the auction paperwork and also original logbooks for it.
Also comes with a new Sony MEXBT2500 headunit.
Exterior is excellent, and the interior is in top shape also.
Be one of the first to own a MANUAL GT-T, lighter than the automatic, and a true sports wagon!
This car is a very nice dark blue metallic. It has a power sunroof and a factory bodykit.
Great value for money - more power than an '02 WRX, less km's than most, and also less expensive!
Asking: $18,000 (inc. rego and RWC) ONO
Contact:
Rob, mobile: 0402222373
Email: [email protected]
Edited by CoolPC
  • 2 months later...
  • 3 weeks later...
    • I was just going through this on Neil's car (33 gtst). Assuming you are using standard AAC and Cold start valves, you need Post Turbo Pre throttle to Boost Controller (if you have one) then to Turbo Wastegate Pre throttle to AAC input AAC input T piece to Cold start input Cold start output to plenum post throttle AAC Output to plenum post throttle AAC Output to brake booster (needs a 1 way valve) Plenum post throttle to Fuel Pressure Regulator Plenum post throttle to Blow off valve signal Plenum post throttle to Boost controller input (if you have one)
    • I’m trying to figure out the purpose of these fittings. Assuming they’re for coolant but not sure where the lead to. I know the bigger one on the right (which isn’t filled) is the brake booster. If anyone has a photo of a diagram of this intake or has a set of instructions it’d be greatly appreciated
    • How much is that r32? Is that $170k or $1.7m
    • Ahhh! My silly brain was thinking Nissan started selling them straight away, but they waited w or three years didn't they?   Maybe Duncan should build an R35 race car over the V37... There's a cheap yellow one on car sales Duncan, would only need your splash of purple added...
    • Welcome (back) Gaston! Keep us up to date with the hunt!
