famous is great, except the rule that you have to park on your property at night or its not insured.
it was a Biatch to get my car up my driveway in my old house, and in my new house i cant at all, im still fighting with the council to get them to fix my driveway :D
Ash.
  • Replies 283
Ash.
You don't have to park on your property overnight to be covered. If the car is within 500m of your place of residence, it needs to be in a lockup garage overnight to be covered against theft. It doesn't have to be your garage. And you are covered if you leave it outside overnight more than 500m away. This is just to stop people leaving their car exposed to car thieves overnight in the street or in a driveway where they are easy to steal. Personally I welcome this because it's dropped my premium over the past couple of years. I've read a lot of posts from people whose cars got stolen from their driveway or in the street in front of their house, and I am glad that my insurance money is not funding any cars that have gone missing in this way. I'm not saying that I don't feel for these people, but I'm glad I don't have to pay for it.
cant park outside @ night?
i thought u could but not within a certain close distance in which you have to garage it?
edit: i got my cheapest quote with Famous.. great help on the phone and was very polite.. think her name is Julianna or something
yeah your right, i should have made that more clear, i did mean the rule where it has to be within 500M from your house in a Garage...
also the westfield here is within 500M from my house (i think...) so i wonder if im at the movies and the car gets stolen if its covered?
Ash.
    • They care about emissions, and cost the most. Save weight where possible, and make manufacturing easier. Less material also let's the engine transfer heat to water quicker, and bring the engine up to temp quicker, better for emissions and getting them past their warranty period.
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
