Time choice required.
32 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 219
I'll come along.
i think i'm busy that day
yeah u are liz... attending this dinner
it's too far
I know what will get you there: let's make a bet on your attendance?!?!
umm 5days after this is my birthday :thumbsup:
But im over birthdays so i wont have a birthday.
Don't you wanna finally become an adult, Vic?
hey man
i didnt mean that as a racist comment
just a thoughtless joke .....note for next time
hahaha D_I_F is a chick, and she's white as the moon :laughing-smiley-014:
I wouldn't worry about it too much, we just like to stay politically correct :thumbsup:
I don't even know if you are or you aren't now but I don't care either way. We will protect you from the evil doers. And you wont be the only one of "them" there I can assure you. haha. We're a mixed lot, a melting pot, a multicultural bunch, a mixed salad, a leftovers stew, a multifaceted entity, a bit of this a bit of that and a whole lot of craptalking besides.
Isn't that right Rukus? Actually Rukus hasn't posted yet. I'm going to mark him down as coming anyway. He'll like that. He likes being told what to do.
See you there Mr AYY.10Z if that is indeed your real name!!!!!!!!!!!!!!!!!!!!11111111
Ill be there providing my engine is running on more than 4 cylinders :thumbsup:
You can probably make it on 3 but someone can pick you up otherwise. I'm putting you down. (you smell and your taste in clothes leaves a lot to be desired.)
Thanks for that Abo bob.................... i am sorry for that comment
I will be there at hog breath at cronulla and cant wait to meet you all
i have also just send my membership paper thru via mail
AYY.10Z in my number plate... My real name is charlie.......................
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
