Drifting
Hey guys, i was just wondering i'm here in rainy melbourne and i dont do it often but sometimes if there is an a wide open road with a highly visable corner i'll play drift.
My amature technique is to hold the clutch in 2nd or 3rd, give it a bit of revs and let her rip whilst throwing a bit of opposite lock, it works a treat.. but there must be other ways of setting up a drift?
I was also wondering does anyone in Victoria hold drift track days, i'd like to practice more on a track rather than on the street.
And lastly are the skylines easy drifters?
cheers
Anthony :)
Depends what sort of skyline you mean. 32's seem to be pretty good, not many people drift 33's are they're pretty heavy, and no one really drifts 34's cause they're so expensive.
That doesn't mean it can't be done though.
That's pretty much the easiest way to drift, if it's a really big wide long corner, just hit it at pace and turn hard, if it's wet the bum should come out a bit and spin the wheels and the car will come sideways. I don't know about Victoria, but we had a skidpan day up here recently, my car was broken and I couldn't go :) but that's basically all the day was.
Guest Simon-MrRx7
acctualkly its safer in the wet.. easier to break traction therefore speeds are lower, if u loop it u just usually spin out in ya own car length..
when its dry your pushing it harder and faster... if u loose it.. cange are u gonna hit something harder.
Wet is also better for tyres :)
i was once getting a new set of rear on my rx7 every 2nd week :(
Best place to drift is turn 2 at EC... second best place is turn 9 at EC.
Wet is better for tyres, and easier to get it all hanging out... but it is also easier to lose it!
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
