Hey Mexicans I dont speak spanish so I will keep it simple :thumbsup:
I and a few others are making the trip down again for DECA just want to give you a heads up as it seems that some where very upset that we where better then most! :(
But I am bringing my car this time ( SMOKY WONT LET ME DRIVE HIS NOW )
But dont be intimidated from our driving experience we wont hold it against you :)
But on a sad note stevo has informed me that since he can not handle his grog he will not be attending this final event actually it may be a good thing NO POOPRA will be there YAH!
bla bla bla will post more crap on here later!
:mellow:
https://www.sau.com.au/forums/topic/186832-final-deca-for-2007/
  • Replies 103
Oh seriously if anyone has been from Vic has a Digital camera and I guess there wont be allot I would love them to take some good photos for me as I will put together an artical for HPI no pormisies that it will be in it but I will do my best. :thumbsup:
Andrew - will send you accommodation details via PM.
Ill leave it to you to let any other who are definately coming down to book.
Accommodation is different this time as most of Shepperton is fully booked, so if your coming, I'd suggest booking something ASAP.
Cheers
B
Is this for the event or are you talking about something else?
Help to speak CLEAR English :(:)
surely there's a way to remove your thread starting privileges...
attack this
-thread moved - pointless
Help to speak CLEAR English :yes::P
I was trying to speak mexican sorry ! I was unaware that there are many of you that can read english correctly LOL :O
Unfort I will be not making this trip down, so someone else will have to go for first place in the NSW team, pitty I cant make it third time lucky :)
Good luck to all the other NSW members
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
