  • Replies 103
Are there dates on this yet? I'm keen to go.
No reserved spots is fair considering they had to turn their own members away. I'll get my bank of fax machine all cranked up and ready to attack.....
And Autosalon over DECA - guess those would wold rather look at cars than drive them should go to Autosalon. Lets see, how good do you have to be to drive on a Dyno?
I am waiting for Snowy to get back to me TJ i think it is around the 1st of dec or somthing like that but we need to sort out some where to sleep as the place we stay at is already booked out !
dam mexicans!
And Doof I am not drunk you are !
I dunno... those dyno ramps can be hard to negociate.
Well the only reason that you won is because i was driving smokys car and we blew it up so now the GTR is coming out to play and let me say wont be like you remember it MMMWWWWWAAAAAAHHHHHH
come here big boy@@!!!!!!hahahaha
RWD ftw and tou know it@!!!
everyone knows i am the deca nsw man! hahahshshaq
ah crap, gonna be soooooooooooooooooooooooooooooooooo hungover on caturday i mean saturday
Craig, the only reason u want in is cause im not there and you k ow that meand I cant come first for NSW1 :ninja:
ahaha
rofly at dstarting new threwad!
Go to sleep you drunk
Sif you will be driving it hard/fast
You think that purple thing of yours is going to beat the TJ in White Knight? You so silly Lucy.....
HA HA HA HA funny TJ but they are fighting words Just think if i can come second in a GTST with no experience in driving the car wonder what I can do in the purple people eater LOL
GAME ON!
Im suprised you will drive it that far from its garage :(
:worship: Listen to the man, he's right :rofl: driving all that way to get your ass whooped on and off the circuit is insane. But hey i guess VIC is "the place to be" ;)
My car will hopefully, finally, make an appearance. It may not get in the top twenty, but it will surely look good frying the tyres :)
Craig, the only reason u want in is cause im not there and you k ow that meand I cant come first for NSW1 :)
ahaha
are you drunk :laughing-smiley-014: the Dr said not to take those pills with alcohol.
whats the power of it?
GAME ON!
Game on mate....
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
