  • Replies 50
Definately no chromies vic! lol, and very content with the bose sound at the moment, just upgrading the 6.5" subs on the parcel shelf as they have shitthemselves, and going to upgrade the HU to an audi RNS-E nav, dvd, tv, mp3 etc, very snazzy unit!
the engine is soo tidy, the turbos are down there somewhere i sware!
N1GTR - thanks mate, chip soon, had the trial program on her now i want it!!
best thing about this S4 is all the RS4 goodies bolt up to it! turbos, coolers the lot.... hello stage 3
GoldZilla - its pretty smooth, bit soft ish at low speeds but thats good on sydney roads i guess!
Joeyz
V6 2.7L Induction Twin Turbo intercooled
Power 195kW @ 5800rpm
Torque 400Nm @ 1850rpm-3600rpm
Acceleration 0-100Km/h 5.7 secs
Kerb Weight 1615kg
Fuel Consumption Urban 11.5L/100km
Fuel Consumption Extra Urban 6.6L/100km
Drive Four Wheel Drive
Transmission 6sp Manual
Wink - very sleeper, imports dont know what they have been chopped by and cops dont even bother looking!
Sanger - this car is much preferred over the skyline, but the bouncing boob scenery isnt as good!... and yeah ive got the ski port, dont know what i will do with it just yet...?
yeah but it DEFINATELY dosent feel like it, feels 1400kg max! and very throwable...
FYI
The APR 1.0 Bar performance chip for the 2.7T is good for 307 horsepower (229Kw) and 366 ft. lbs. (496Nm) of torque.
Big Upgrade!
FYI
Big Upgrade!
Yeah a mate of mine got the A4 turbo quattro when they were released (the 2004 model i think, not sure) and it felt light as, but was fkn heavy on the scales
Thats some good power for a sleeper car :D
Punctuation my friend...
It's the difference between:
1. I had to help my uncle jack off a horse.
and
2. I had to help my uncle jack, off a horse.
Point taken, must remember not to type while also doing 5 other things at once while at work, must also remember never to put my surfboard in my girlfriend again!!!!!!
Ok im getting the Haysey plates remade....
im thinking either white on blue (its a very similar blue to the car so will look ok)
or silver on black...
opinions?
Choose pink to reflect your new found metrosexuality
EDIT: Rofl 2 jokes about ed being metro in a minute.
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
