Stacks Of Cheap/free Parts For S13 & Imports
Pics here
http://www.skylinesaustralia.com/forums/t186873.html
Item Condition: See descriptions
Reason for Selling: Moving away
Price and Payment Conditions: Cash. Pickup only for larger items
Pictures: Below
Contact Details: PM me or email [email protected]
4x Stagea rims $200
16x7 in 5x114.3 pattern lightweight forged BBS style rims fitted with shagged tyres. Comes with slip on spacers to clear larger calipers.
s13/14/15 drivers rail $130
Wysteria brand rail to suit bottom mount seat. Has adaptor plate, should suit all Bride/Recaro/Sparco seats.
Goodyear tyres $20 each
4x 245/45/17 Goodyear Revspecs (top of the line, was quoted $400+ each) that came with my GTR from Japan. All have some camber wear but decent tread across most of the face. Pics coming soon(ish).
Tyres to suit above $20 each
225/50/16 30% Federals x2 & 70% Firestones x2
S14/S15/R32/Z32 Rotors $40
Pair of 280x30mm rotors in good condition, full thickness still
S13 Silvia guard $50
Black, left hand side, good condition guard (white line is light reflection).
Autometer ProComp Boost gauge $30
No-longer liquid filled but works well. Come with stand.
Edited by neil_se
Dash taken, semi-slicks and FMIC on hold.
Also have:
s13/14/15 drivers rail $140
Goodyear tyres $30 each
Hehe, i'm just being honest. It looks like a 260z dash :lol: Didn't have any vents or anything (and i cracked most of mine swapping it over :) ).
Dash, intercooler and semi-slicks gone. May consider offers on other items.
Edited by neil_se
No sorry, i need them for another set of rims if they don't go with these ones.
Rotors on hold pending payment.
Firestones sold. I just had a closer look at the Federals and they're right on the indicators on 1 side so i'll take $15 each, still decent tread across the middle for drift tyres.
Edited by neil_se
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
