Step one.
Start with an N1 as a base car, as you'll need the N1 oil cooler. you CANNOT fit a non standard oil cooler, radiator, turbos, cams, anything really to a targa car.
You can however build a standard car into an N1 but you need to use all N1 parts. Not sure whether you've seen the price of a genuine N1 oil cooler, but you wont get much change from $11,000 :):(
So, start with the car that has everything you want already fitted from factory.
An N1 should do nicely.
And NO, you can't ran the Z-Tune. Targa Tas has banned it :O
GTRs are heavy beasts. Even a fully stripped out race car is still going to way north of 1500 kgs including cage.
Power.... well as much as you can make out of "stock turbos" and "stock engine"
hmmm, it is possible to get it down to 1200kg :blush: there are r32 gtr running in that region in japan and the r33 seem to be around the 1300-1400kg mark
Our R33 N1 weighs 1580kg (lowest alowed) and has 318 rwkw, can't remember tourque. If you run the N1 turbo's your gunna get lag (wich you have to run if you run N1 spec). But the N1 revs harder so you still get a decent powerband (we run ours to 8500, apparenlty the whites ran their R34 to 9000)
Spec M2 has to run standard weight (1540 kg) + 40kg.
Edited by sav man
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
