Used my duel optical since around 2002 ish. Cost over $100.00 best investment made.
Time to upgrade to duel laser.
First person is so much better, how ever they dont work on everything (some table tops ect)
My 2c
i use the track ball mouse (the one with the big red ball on top ) ive had it for 9 years il never go back to a normal ball /lazer mouse again hell ive even gone out and bought a spare one for when this one dies
Edited by japwpn
Hahahaha I still use an original microsoft mouse....has the ball and no scroll wheel :P
Might as well dust off the chisel and go back to writing on rock tablets its such old tech :D
Mines an IBM original...had to drop the ball out of it and clean the rollers in it last night
I've been using a wacom graphire at home since 2002 which I scored when I upgraded to a Intuos at work. so my pc's totally miceless.
edit: actually i tell a fib, sometimes some apps don't support it, which is when the MS optical mouse comes out of the drawer.
i got an intuos 3 at home, used to do a lot of flash animation, now i use it mostly in photoshop for painting crap
I use a laser mouse, i'm part nerd :down: due to my job :ermm:
Nah, seriously though, if you want a mouse that works on every surface, is extremely reliable and uses one set of batteries every 6 months try a laser,
I've got a laser desktop, wireless keyboard and mouse set, only cost just over $100
http://pcpacific.net/product_info.php?products_id=1786
There is no cool red light like an optical, but when you have an optical running on batteries and change them once a week or so, it gets pretty annoying
cordless FTL. latency, weight from batteries, lower resolution and constantly having to recharge all makes them blow goats, and the only decent cordless ones that solve these issues are like over $100 for the mouse alone. I can deal with a wire attached to my PC.
yeh mines wired and laser, 2400 dpi if i remember correctly so has plenty of resolution, dont need to bump up the OS respose and loose your accuracy. not a fan of wireless ones unless they have a dock instead of batteries
always wondered with the price of cast polymer batteries in mobile phones why they couldn't make a cheap rechargeable mouse that's light and has no need for AAA batteries.
    • Stock RB fuel pressure is near enough 43.5 psi, so the latency in that table at 31.6 will be close. You can see that 7 or 8 psi equates to about 0.4µs extra latency. So if you wanted to interpolate between the 31.6 and 39.9 psi values you could say you're going up about 2 psi out of those 8, so add about 0.1µs, which is barely worth talking about and is quite possibly wrong because ideally you would fix the latency while running at the appropriate conditions on the dyno, with a wideband sniffing its butt.
    • The pressure, is what you set the fuel pressure to. If you have the factory fuel reg, you'll need to find the factory spec. I don't know it off the top of my head, but someone else might.
    • For others, what GTSBoy states here should be paid attention. Why? Well lots of people play with different engines, and they LOVE to change things like remove AC, or steering pumps etc, and it lends to them needing to move the tensioner too. You want your tensioner, particularly those that are sprung or hydraulically tensioned, to be the first thing after the harmonic balancer, or technically the "last" pulley in the chain. By saying last pulley, I mean look at the direction the crank spins when the engine is running, follow the belt from where the crank is pulling the belt FROM, and keep following that until you're between the last pulley/accessory on the belt and about to reach the crank again, this is the spot where you put the tensioner. This is the area that will always end up with slack. This is worked out exactly the same way for chains too, as the physics is the same for them. The crank pulley is where all the force to drag the belt around comes from. You will never ever get rid of the slack that appears, especially under load. The tensioners job is to keep the belt loose enough when stationary that there shouldn't be out of sync movement in slow movement, and then be tight enough when running, that the belt can't jump off any gear and get damaged. Too tight, bad things happen, too loose, bad things happen. Have a tensioner (mainly sprung/hydraulic one) in the wrong spot, it can't actually do anything about keeping the tension.
    • It was gonna take much longer for the 440cc so I'd thought I'd risk it with the 550cc. They finally arrived and I couldn't wait any longer (I could but I was quite excited after 2 months) and installed them myself. Removed the old injectors, inserted the new and connected everything up. Before starting the car, I tuned the injector size from the factory 270cc to 550cc using Nistune.   This did some of the calculations automatically which catered for the TIM. The latency however did not seem to change. Deatschwerks have the tuning data available for each injector online, and I had a look at it. It has a table which relates to latency according to pressure and voltage (see below image). Nistune requires the 14v value, but I am unsure of which pressure value to look at (my lack of knowledge and experience have something to do with this). The highlighted value is close to my current latency which is 760µs. It is for 14v which makes sense, and the pressure is 31.6 Psi.   I still gave the car a test drive to see how it goes, and honestly it has never felt so powerful before (and some people say the RB20DE is very weak?). I really enjoyed the drive. Side note; The injectors are quite noisy, which someone mentioned before. This does not really bother me however. I will still ask my mechanic to have a look at it and perhaps ask a tuner to fine tune it if they have the knowledge.
    • Also true. But imagine not wanting new injectors? Imagine wanting to use 30 year old injectors?
