Please Help Me I Need My Rb20det 240sx To Run. Hasn't Ran In 3 Months Now.
i need the wiring diagram for a rb20det tps.... I have a black connector 3 wires,,, and third yellow wire just hangs off and is not connected to anything and I can't find the other end of the wire anywhere under the harness or mainfold.
There are actually 2 connections - a SENSOR, and a SWITCH
The sensor has continuous variable resistance between pin 2 (middle pin) and Pins 1 & 3. The switch is On-Off between Pins 2 & 3 (it tells the ECU that throttle is shut).
SENSOR - Pin 1 connects to ECU Pin 48. Pin 2 connects to ECU Pin 38. Pin 3 connects to ECU Pin 30 (and to A/T control unit)
SWITCH - Pin 1 connects to ECU Pin 54. Pin 2 connects to ECU Pin 57. Pin 3 goes to A/T control unit.
can you please post a picture for me?
ok in this picture i have it in red paint with red circle around it.... its a grey plug its 2 wires if i am correct it shouuld only have 2 pins and the third pin is empty?
but on my rb20 my tps on my plug it is not grey its a small black plug connector and it has 3 wires coming out of it, and 1 is a yellow wire that I can't seem to find a home for it, and if it helps my ecu is auto ecu so i was told the yellow wire i have is a auto kickdown b/s thing but i really dont know I just want it hooked up and wired right...
the problem is on my rb20, with the black connector plugged into my tps, the car will not rev and kinda idle's rough.... But if I unplugged it the high is sky high like 3 grand and still seem rough, but it will rev just fine without cutting off.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
