So my mechanic is dead set on his supplier charging 600-700 for a gates timing belt kit (rb25det) which i think is retarded given that justjap.com sells the exact same thing for 349.
Should i just order online and get it fitted rather than paying that ridiculous mark-up?
https://www.sau.com.au/forums/topic/186949-major-service-timing-belt/
wats a timing belt kit?
i just bought the timing belt from nissan for 80 bux
yeap
where in vic are ya?? coz when doing timing belt water pump is reccomended as well
RE customs will be doing my timing belt and water bump using gates timing belt kit and new OEM nissan water pump for $750 and thats them supplying the aprts and fitting them
Edited by ashneel
http://www.justjap.com/gatesbeltkit.htm
KIT CONTENTS
Gates Racing Silicon Timing Belt
Genuine NSK Idler Bearing
Genuine NSK Adjuster Bearing
Camshaft Seals (2 Pcs)
Crankshaft Seal (1 Pcs)
im in the northern suburbs, where is re customs? My guy is like a family friend and wants to charge about 300 labor if i get the belt myself
edit: oh springvale, yeah out of the way for me.
Edited by delljit
timing belt kit consist of the timing belt itself plus idler bearing, adjuster beargin, camshaft seal and crank shaft seal
your better of changing all those while the belt is being done
hope that helps :D
Ash
Edit: heres the link of the gates timing belt kit for a R33 and shows whats in the kit http://www.justjap.com/gatesbeltkit.htm
Edited by ashneel
yeap
hmmm interesting, ive done this all before and i get trade price at bursons, so i know what this stuff costs for a mechanic to buy.....
and
genuine water pump $68
gates timing belt $63
new idler and tensioner $108 for both
crank shaft seal $11
so that = $250 for parts
they are making a lazy $500, for what will take them probably 3 hours
good money i say!
its great knowing how much shit actually costs! people would save sooooo much money if they realised you dont really need special tools or alot of know how to be able to do this stuff yourself! its actually quite easy, just takes a whole day of your time when your taking it easy at home without a hoist and power/air tools
nb. you need harmonic balancer puller (beg, borrow or steal for 3 mins)
and timing gun if you happen to forget where your CAS was set too.... so use a texta peoples!
other then that you only need a small socket set and an allen key set and maybe a screw driver!
Edited by Ruffels
Yeah, i dont mean to be the bearer of bad tidings.
But this topic is exceptionally common, and there are a number of people who have posted *in detail* threads about Vic prices, where they did it, what was done and so on.
Please take the time to have a look through the link Adz posted above.
Any problems, PM me.
Cheers
Guest
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
