Na tyre size change could, i was out by 10 km per hour will just 2 size smaller profile (same rim)
So if you are increasing/ decreasing the out side diamitor of the tyre you are changing you speedo reading...
You will also be putting more or less km on the car.
https://www.sau.com.au/forums/topic/186959-speedo/#findComment-3377693
havnt done anything to the car to do with the gearbox or diff. have now got 18s but it was still like this with the stockies. i reckon i could have a R33 gearbox but can you tell if it is??
https://www.sau.com.au/forums/topic/186959-speedo/#findComment-3378098
yer tyres can make that difference.
RPM / gear ratio / diff ratio x tyre circumfrence in metres x 60 = KPH
GTR 4th gear is direct so easier to calculate
18 x 240 x 40 tyre is 2.05 metres in circumfrence
17 x 235 x 40 tyre is 1.95 metres
7000 / 1 /4.11 x 2.05 x 60 = 209.4 KPH
7000 / 1 /4.11 x 1.95 x 60 = 199.27 KPH
https://www.sau.com.au/forums/topic/186959-speedo/#findComment-3380080
