Hey everyone I am considering swaping my FC RX7 for some thing else, the rx7 has heaps done to it. Every thing on the car is less than 6000km old.
Mods are
: Fully rebuilt engine including custom bearings and springs, ported and dowled, ported oil gallories with custom oil squirter things, aftermarket main seals and corner seals, ARP stud kit and heaps of other little stuff.
: T04z turbo from gcg
: Tial 44mm external waste gate and screamer pipe
: custom manifold
: Custom twin 3" exhaust system with twin chrome dump tips
: custom front mount intercooler ( by race radiators )
: 2 rorchester 1000cc injectors and 2 550cc injectors.
: custom alloy radiator ( by race radiators )
: custom alloy milled inlet
: sard fule reg
: wolf 3D V4 computer
: extream button clutch
: extream custom fly wheel
: re built S5 gear box
: mazspeed 2way mechanical diff
: cusco coil overs front and rear
: allot of custom suspension and under body reenforcement has been done
: cusco 7 point roll cage.
: 2x sparco seats
: hydrualic hand brake( from revolution race gear not a cheap one )
: endless brake pads top of the range
: 3 pice Volk wheels (new) front are 17"x8" and the front are 17"x9"
: Bridgestone RE55 semi slicks front are 235x45x17 and rears are 255x40x17 cost me $1600 and have only done 100km on the street
: Paint Glasruit 2 pak ford narooma blue was painted about 3 years ago a few imperfections but a cut and pollish would bring it up realy well as it was'nt a cheap paint job.
there are more things I will add as i remember. and receipts will be available to the buyer for most of the work done. This car is a Beast it has made 296 rwkw on 14 psi and a verry conservetive tune and pump fule, it WILL make 500rwkw on high boost and C16 race fule and to do that it just needs 2 1600cc injectors put where the 1000cc ones are and to put the 1000cc ones where the 550cc ones are now. This car is one of the fastest revving cars i have ever been in as soon as you hit 4000rpm and the gate opens it is bouncing of the rev limiter. The thing is heaps of fun and will scare pretty much anyone who drives it. The only things that need doing on the car aree there is a dint in the drivers rear 1/4 panle and victor at jetspeed has quoted $600 to do that and the usual rust that just keeps coming back in the sun roof but i will fit a new caron fibre sunroof and and have the rear 1/4 fixed and painted if some one offers me the right deal.
If I was to sell it for cash instead of swap it i would ask around $20,000 ono but I am open to all sorts of swap offers.
espesialy interested in R32 Gtr or highly modded gtst, ceffys, aristos and heaps of other cars just want to play with some thing different so let me know what youve got and we will see how we go
please reply in the thread or pm me and i will put up my new mobile number tomorrow or the next day, Cheers sean.
Edited by WHITE R33
https://www.sau.com.au/forums/topic/186960-300rwkw-fc-rx7-up-for-swaps/
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
