Long story short.
My brothers got a MY00 WRX, it has a slight hesitation or a miss down low in the revs when its not on boost and when its cold. He's tried new plugs and leads and fuel filter to no avail.
He does however have an S15 pump in there (came in the car when he bought it). It has a FMIC, turbo-back exhaust and pod in the mod department.
Would it be better if he's throw in my Stock R33 pump in? Would this help with the hesitation?
ps, I'd be posting this on rexnet except they won't accept my email to sign up.
Cheers guys :blush:
https://www.sau.com.au/forums/topic/186976-wrx-surging/
walbro pump would be the smartest cheapest option for a pump for a rexy.
Yes it would be. But we're trying to get this one down to a cheap as possible solution, but if it really came down to it and we really had to we'll get walbro. Better to do it right the first time.
But the R33 pump has got be better than the S15 pump wouldn't it? It'll be a larger sized pump than the stock wrx and s15 pump. Might be a touch harder to fit. I'm not even sure it's the problem, it probably isn't. Just another possibility maybe.
There might be a "flat" (wear) spot in the TPS that sends the "wrong" signal to the ECU.
Wear spot on the TPS? That's a new one to me. Please elaborate. How can I check the TPS?
Cheers guys :blush:
Edited by KeyMaker
https://www.sau.com.au/forums/topic/186976-wrx-surging/#findComment-3376833
  • 4 weeks later...
If i remember right 040 wont fit without mods, you can pick up walbro pump kits off ebay and formums liek rex met for around $125. I have one on the way for my liberty and they are pretty much the same set up.
AFM's f**k up on them a fair but as well.Try cleaning it out and see what happens.
https://www.sau.com.au/forums/topic/186976-wrx-surging/#findComment-3426636
I don't think its the fuel pump. If it was it would break down even more under load.
It could be the AFM, but it only seems to happen when the cars cold, when it warms up its fine.
Common problem with the MY99-00 , check airflow senser and clean............
https://www.sau.com.au/forums/topic/186976-wrx-surging/#findComment-3427192
I had the same problem in both my GT Foresters but much worse, it was the AFM both times. How many kms has it done? It is a common problem around 150,000kms+.
If it is the same AFM as the Forester (the '00 model one I just bought was the same as the WRX) it will be around $200 for a '98/'99 model and $750 for a '00/'01/'02.
edit: Also note, if it is the AFM is it running extremely lean (Forester was running 17 AFR and pinging audibly). Get it fixed asap before it costs you a motor.
Edited by Willo
https://www.sau.com.au/forums/topic/186976-wrx-surging/#findComment-3435441
Is it missing at idle or is there hesitation (or actual misfiring) in the low revs when accelerating? More info.
It hesitates(a single hesitation) low in the revs when accelerating.
So you reckon just a clean won't fix it? What if we re-solder all the points on the PCB board like when you fix skyline AFM's?
https://www.sau.com.au/forums/topic/186976-wrx-surging/#findComment-3436844
Cleaning doesn't do anything. I have no idea where the failure point is so couldn't tell if it would fix it or not.
https://www.sau.com.au/forums/topic/186976-wrx-surging/#findComment-3436853
    • Hey Daniel, sorry to hear that and thanks for posting up for us at a really hard time I only knew SmoothLine through the forums, we never met as we are based in different states, but when he was most active on here he was quite a while back so not many of the current crowd might remember him. I am pretty sure he was active in the Queensland SQU club but that is defunct now too (times are changing and we are all getting older). Farewell SmoothLine!
    • Turns out depending on whether the car was equipped with TCS or not there are different signals coming to the dash, meaning there are different speedo clusters.  Wired in a speedo calibrator box from aliexpress and now works fine.
    • Thanks for the nice comments, I really appreciate it.  Regarding mods, I am planning of keeping it mostly stock. The only possible future mods I am thinking of are new wheels, perhaps sports shocks or coilovers, and was about to do a cat delete on Monday (However, I am unsure about this and I am getting cold feet). Despite this modifications, I'd still keep all the original wheels/parts.
    • Hi All, I’m looking for a R34 GTR rear propshaft for my getrag conversion in my R33. If anyone has one available send me a message. Thank you  Roy
    • Yep I ended up buying a new gasket and no leaks since.
