hi,
I got the rb25det i've been wanting for so long and put into my car, But I am having some problems boosting above .6
I have a walbro pump and sard regulator stock injectors and everything is stock the turbo is stock too
My electronic boost controller is the Greddy E01, I've tried all sorts of settings but the boost wont go higher then 0.6 before it starts going burrrrrr and very hesistant boost cut or some thing like that. it's fast until it gets really close to the 0.6!
I have set the setting to about 0.55 and sometimes i get micro hesistations! at .55 but not many as i keep rolling the setting lower until it is smoother! but the largest problem is the boost! I wanna try 0.8 or even 1 bar but cannot go that high.
the engine was imported from japan and has very low km/s about 20-30,000 kms had the ports polished and all that! and put the new gasket so it sound great!
anyone can tell me stock engine is okay at 0.8-1bar? and what are your ideas?
thanks guys!
Shaun
https://www.sau.com.au/forums/topic/186980-wont-boost-more-than-6-bar/
Agreed, shouldn't be stuffing around with Fuel Prerssure Regulators without a tuned ECU.
Not worth the trouble anyway, take it off and sell it.
Put the standard FPR back on and then play with your boost and see what happans....
Might clear it up
Edited by Birnie
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
