http://www.skylinesaustralia.com/forums/t186034.html
Hi all,
This is the NSW club thread about an SAU display this year at AutoSalon Final battle, Im seriously considering entering (not 100% yet though) and I think that we should get at least another 2 ACT cars to go aswell.
Your car doesnt have to be a show stopper or a power king, we just want as many nice Skyline's, Silvia's, 180's Datsun's whatever (as long as it has a Nissan badge) to come along and make up numbers.
So who's interested?
https://www.sau.com.au/forums/topic/186986-autosalon-final-battle/
Ive never been to one, what happens, what does it cost, etc etc
Didn't I read somewhere that its on the same time as Bathurst track day? Dates don't seem to match up with it though.
Since I seem to be the only Datsun owner, the car wont be ready for it and there is no way in hell i would ever swap a Datsun badge for a Nissan badge :down::ermm:
Yeh I knew what you meant.
I went to one in Melbourne 2 years ago, the dyno event was good and there were some sweet rides there, but I found it boring without any driving going on.
I heard a rumor they would only accept ACT cars if they had Franjipani stickers :down:
I heard a rumor they would only accept ACT cars if they had Franjipani stickers :ermm:
bahahaha! yeah probabaly :down:
it does get a bit old after you've walked around once or twice, and there are no driving events. still good to check out some sweet cars and babes :PBJ:
they never used to charge "competitors", but this year it's about $120. we're in the process of working something out with them though.. last i heard anyway. not sure on public entry prices. should be a website somewhere...
*psst* Amaru... I'd hang low for a few days if I were you, it won't be safe around here
You obviously have not met Amaru even with Mick's guns i think the giant would have him :(
although if you get to know him a little better you will find out he is really just a little pussy cat trapped in a giants body :(
I would certainly use the word "Pussy" to describe Nick, I dont know about "cat" though.... Hehehe :blink:
P.S. You people are going to cause me to go on an SAU shooting rampage... Im serious, I will crack sometime... :)
Are you going to use the frangipani wheel caps at Auto Salon?
  • 1 month later...
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
