Hey everyone,
I've got a rather random problem with my GTR that is random is the sence is happens randomly, but annoying non the less. :)
Basically the fuel cut is activating at around 2800 RPM, which is most probably just before the Turbos start to spool. I've had this problem since i brought it but has only happened on 2 occasions prior to this.
I use BP ultimate, stock ECU and only an aftermarket FMIC and pods.
Could this be related to my Coil packs or a faulty connection between the AFM and ECU, or is it something more annoying like the internal wastegate. But again is doesnt happen very often and when it doesnt my car runs perfectly.
Cheers
https://www.sau.com.au/forums/topic/187000-why-is-my-gtr-acting-like-windows/
Are you sure that its the fuel cut?
I would start with the process of elimination technique...
Try replacing your O2 sensor first and check that you AFM isnt filthy dirty (check the little wire inside the actual AFM housing, spray with electronics parts cleaner, or carbie cleaner).
Check that your crank angle sensor is still working, you'll need to borrow someone elses for this...
Then check coils, plugs etc.
Other than that Im not sure what it could be.
Check all vacuum lines and intercooler piping for any leaks or loose clamps. As its starting to build positive boost pressure it may be blowing open a small leak.
Clean the AFM as suggested above, o2 sensor I wouldnt worry about too much (as mine ran fine for years without) and also check the o-rings on the injectors (the problem that elluded me for 6 months).
Well today it worked fine and then while i was driving it started up again and when i was driving back from CIT it just stopped when I was at a set of lights. It is very random but I do recall the guy i brought them off saying the coils will require replacing sooner down the trace as they are getting worn or whatever they do in their old age. I've checked the intercooler piping when I put the plumback pipe on and they seem fine. I'll give the AFMs a clean and the actual connectors, as I think this might be the problem if not the coils. But I'll do everything that has been mentioned as it could be one of those aswell.
CHEERS!
If your coils need replacing then they will most likely be cracked due to the plastic they're made from cracking, causing the spark to "arc" (jump out the side rather than travel down through the spark plug), but Ive never heard of it being so bad that it actually cut the engine, it usually just causes it to run really rough.
I would be checking the fuel pump if I were you, sounds like its cutting in and out intermittently.
I had what sounds like the same problem, and it was one of my air flow meters. I just had some z32's put in so i've got 2 stockies that you can borrow to test if you need. Only problem is that I'm away with work work for another week, if you want them then just PM me.
Cheers,
Brad
Hey, I'm giving the AFMs a clean right now. I not sure if the fuel pump is to blame as it cuts at the same spot everytime and not at a random time. I'm thinking the ECU isnt letting the REV range go above when the turbos start to spool as it thinks there isnt enough air to run them efficently, that if it is the AFMs.
See how the clean goes. If it still having a problem, I might have to borrow yours for a test Brad.
THANKS!
THANKS!
hi mate, it stuart swing your car past work and we will plug your car into my scan tool and see if it comes up with any codes.
Gave it a drive today and didnt have the problem, but judging from the past it has to be problem free for 2 weeks before I say the problem is resolved...On a more stupid note my other cars battery went flat while i was driving home...in the dark...oh why are the headlights dimming and why does my Revometer show Zero while in going 60...lol maybe my alternator carked it i dunno. But I'll be dropping in my GTR to ya soon Stuart as I'm getting the roadwortthy do at PW aswell as my CV boot issues. :laugh: But it would be nice to see if anything else isnt right with my GTR.
I also found out one of my pods is half crushed...Those Apexi ones arent really that cheap are they ><
Hey ya!
I think the AFM clean fixed the problem as it has been going good for 2 days now and ive noticed it a bit more responsive.
Thanks for all your help but if it appears again its back to the list of elimination.
CHEERS!!
P.S. You get muck with my honda civic on monday Stuart, alternator is either dead or near enough to it.
A/f meters are a common thing on these cars,if it happens again i would try borrowing some as the symptons you have are what you will get when an air flow meter goes.
Nah, the whole fuel cut problem is fixed now...but another problem which was probably being hidden by the preveous has started. Basically I remember reading something that may be about it and they described it as 'engine sounds like a subaru engine' So basically is runs rather rough at times and has no power and at other times its completly fine and then it goes back. I could be acceleration it rather aggresivly and still be as slow as my other car. I might take up Suka's offer and take it down to his work and get it computer checked.
Cheers!
OMFG... My car is now swapping between two problems. On its that one of the coil packs decided to work or not on a day to day basis and the other is still the same problem I had before. I had the AFMs tested and they are both giving the same constant reading so one isnt broken. Its on and off and even stops while im driving and i know this and the cars revs drop a little and then its fine. I think my car is cursed as the fuel meter decided to work or not...its working now but before it was at rest position (sitting on the little plastic thing to stop it moving more down) and before that it just sat on quater of a tank even if the tank was full. Ive had a diagnostic on the engine and it said nothing was wrong. Grrr, it going to check the O rings on the injectors and think about who can check the fuel pump pressure, but chances are when i book it in the car will be running fine. Maybe i have to get an inline fuel pressure gauge to see if it is unusually low. And maybe a ECU reset just for the fun of it.
CHEERS!
Go see John at Trojan motorsport. The money your spending on finding the problem could be spent and to find and resolve it in a very short time.
Edited by race_snooze
    • Yeah everyone always seems to refer to them as S13 wheels however they came on R32 Skyline, A31 Cefiro, C33 Laurel etc., and also came polished diamond cut or painted depending on the model. Congrats on your GTS purchase! I'd personally leave it NA.
    • In this thing about this 100% renewal energy stuff I hear no one really talking about anything other than power and fuel really Power and fuel, whilst being a huge part of how we use the billion year old Dinosaur juices, are only 2, of the probably thousands of things that we need to use it for in the chemicals industries for making nearly everything we use nowadays I'm all for a clean planet, but if we want to continue to have all the day to day appliances and stuff that we rely on everyday we will still need fossil fuels Whilst I do love science, and how it can bring innovation, there's really a limit to how far it can go in relation to "going green" As for EV's, unless your charging of your own solar panels, it isn't helping the environment when you consider the the batteries, the mining processes required,  the manufacturing process required, and how long a batteries (read: the vehicle) lasts long term If I was supreme dictator of the world, I would ban the use of sugar for fizzy drinks and food additives and use that for ethanol manufacturing, petrol engines would be happier, and people would be alot healthier  Disclaimer: Whiskey manufacturing would still be required, so says the supreme dictator of the world Same same for all the vegetable oils that get pumped into all our food, use that for bio diesel Disclaimer: the supreme dictator would still require olive oil to dip his bread in This would take some of heat off the use of the use of fossil fuels which are required for everything we use, unless you want to go back to pre 1800 for heat and power, or the early 1900's for plastics and every thing else that has come from cracking ethylene  Would I be a fair and just dictator, nope, and I would probably be assassinated within my first few months, but would my cunning plan work, maybe, for a while, maybe not Meh, in the end in an over opinionated mildly educated arsehole typing out my vomit on my mobile phone, which wouldn't be possible without fossil fuels And if your into conspiracies, we only need the fossil fuels to last until a meteor hits, or thermonuclear annihilation, that would definitely fix our need for fossil fuels for manufacturing and power issues for quite some time  Meh, time for this boomer to cook his lunch on his electric stove and then maybe go for a drive in my petrol car, for fun
    • It really helps that light duty vehicles have absolutely appalling average efficiency due to poor average load. Like 25% average brake thermal efficiency when peak is somewhere around 38% these days. So even a 60% BTE stationary natural gas plant + transmission and charging losses still doing much better with an EV than conventional ICE. And that's before we get into renewables or "low carbon nonrenewable" nuclear which makes it a no-brainer, basically. In commercial aircraft or heavy duty diesel pulling some ridiculous amount of weight across a continent the numbers are much more difficult to make work. I honestly think in 5-10 years we will still be seeing something like the Achates opposed piston diesels in most semi trucks running on a blend of renewable/biodiesel. Applications where the energy density of diesel is just too critical to compromise. CARB is running trials of those engines right now to evaluate in real world drayage ops, probably because they're noticing that the numbers just don't work for electrification unless our plan is to make glorified electric trains with high voltage wires running along every major highway and only a token amount of battery to make it 30 miles or something like that after detaching. Transport emissions is not insignificant especially in the US, but yes there's a lot of industrial processes that also need to be decarbonized. I agree the scale of the problem is pretty insane but EDF managed to generate ~360 TWh from their nuclear reactors last year and this is with decades of underinvestment after the initial big push in the 70s and 80s. I don't think the frame of reference should be solar-limited. France is not exactly a big country either. Maybe it doesn't work everywhere, but it doesn't have to either. We just can't live off of fracking forever and expect things to be ok.
    • Yeah, all the crude is used for fuels and petrochem feedstocks (pesticides, many other chemicals, etc etc). But increasingly over the last few decades, much of the petrochem synthessis has started with methane because NG has been cheaper than oil, cleaner and easier and more consistent to work with, etc etc etc. So it's really had to say what the fraction either way is. Suffice to say - the direct fuels fraction is not insigificant. Heavy transport uses excruciatingly large amounts. Diesel is wasted in jet heaters in North American garages and workshops, thrown down drill holes in quarries, pissed all over the wall to provide electricity to certain outback communities, etc etc. Obviously road transport, and our pet project, recreational consumption camouflaged as road transport, is a smaller fraction of the total liquid HC consumption again. If you're talking aboust Aussie cars' contribution to the absolute total CO2 production of the country, then of course our share of the cubic mile of coal that is used for power generation, metallurgy, etc adds up to a big chunk. Then there is the consumption of timber. Did you know that the production of silicon metal, for example, is done in Australia by using hardwood? And f**king lots and lots and lots of hardwood at that. Until recently, it was f**king jarrah! There are many such sneaky contributors to CO2 production in industry and farming. NG is used in massive quantities in Australia, for power gen, for running huge water pumps (like, 1-2MW sized caterpillar V16 engines running flat out pumping water) for places like mine sites and minerals/metals refineries. And there are just a huge number of those sort of things going on quietly in the background. So NG use is a big fraction of total CO2 production here. I mean, shit, I personally design burners that are used in furnaces here in Oz that use multiple MW of gas all day every day. The largest such that I've done (not here in Oz) was rated to 150MW. One. Single. Gas burner. In a cement clinker kiln. There are thousands of such things out there in the world. There are double digits of them just here in Oz. (OK< just barely double digits now that a lot of them have shut - and they are all <100MW). But it's all the same to me. People in the car world (like this forum's users) would like to think that you only have to create an industrial capability to replace the fuel that they will be using in 10 years time, and imagine that everyone else will be driving EVs. And while the latter part of that is largely true, the liquid HC fuel industry as a whole is so much more massive than the bit used for cars, that there will be no commercial pressure to produce "renewable" "synthetic" fuels just for cars, when 100x that much would still be being burnt straight from the well. You have to replace it all, or you're not doing what is required. And then you get back to my massive numbers. People don't handle massive numbers at all well. Once you get past about 7 or 8 zeros, it becomes meaningless for most people.
