Just woundering what month in 93 did the GTR's come out with the r33 GTR crank and gear box?
Also the n1 block in a standard 94 r32gtr v spec 2 is that the r33 N1 series block??
Cheers
  • The transition to the pull style clutch setup was in the Feb 1993
  • The R32 RB26 also use only one casting (the N1 blocks are only different in the R33 & R34 ranges)
I am unsure of the crank situation, all that the Nissan fast software shows is that entire R32 GTR range was released with the 12200-05U02 however it supersedes to the R33 item which is a 12200-05U03.
  • The R32 RB26 only ever came out with one crankshaft
are your sure about that? I'm fairly certain mid-93 onwards RB26 are essentially R33 spec (larger oil pump drive etc). Also There is just 1 type of N1 block as far as I know.
i can assure you that the 93 (late) GTR's come with a r33 crank. Why cause i am currently rebuilding my engine and it has factory pistons rods crank (and bore) but its the r33 crank.
Also v spec 2 came out with an n1 engine. So i assume its the r33 n1 engine as it came out in 94
Thanks for the info on the month they came out in them.
Cheers
Edited by BNR32t
hmmm, thanks for the input.
But yeah i do have the r33 crank, and to tell you the truth, i dont know how the earlie r32 gtr's keep running. There is almost no contact area for the oil pump.
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
