Airbox Vs Pod Back To Back Testing
Scooby
 Share
Just did some back to back testing using a pair of Blitz steel mesh pods and a stock R32 GTR airbox with paper element filter.
Car pulled 268 rwkw on 10 psi with pods. Fitted airbox and dropped 40 rwkw. Took bottom off airbox and taped panel filter in place, back up to 268 rwkw.
I was a firm believer in using the stock box and panel filter but clearly above certain power levels it has limitations. Just my 2c into the stock airbox vs pods debate.
Cheers
  • Replies 63
The inlet to the side of the box is actually blocked off(r33 gtr box). It is a resonator. You can pull the end of the resonator off so air goes direcly into the box from the inner guard. u get a slight induction noise too lol
ps anyone wanna give me a guide on how to install a ebc on a rb26?? some say u just unhook the factory solenoid and plug it into the ebc solenoid?? i thoiught u would need to do it on the wastegate side??
bonnet down on those tests?
If not , we aren't anywhere.
no, bonnet open. i don't agree that we aren't anywhere. i think we can categorically state that the stock airbox will inhibit power due to the size of the orifice in the bottom half - bonnet up or down - but clearly the panel filter (tested up to those power levels) has the capacity to flow sufficient air if fed correctly.
i know there's a lot more to the issues of airflow and under bonnet dynamics but this shows conclusively that the bottom half of the box can't flow sufficient air.
i'm not suggesting that this is the be all and end all of tests, but it does tell us some things for sure. got to start somewhere, suffice to say i was happy with the outcome as i now know more than i did.
Edited by Scooby
yes..
but
bonnet up with open to air pod filters will obviously breath better than a sealed box with a small intake.
bonnet down would have shown different results on the pod filters I'd say..
especially say after 2 WOT runs.
I strongly disagree that at those power figures that the bonnet open or closed would heavily influence pods at all unless heat was a serious issue, and ACT is still cold. Ther is plenty of available air around the headlight. Clearly the 32 box is a restriction but with modification, say a 90mm water pipe flange and a pipe through the inner guard 33 GTR style it would be more than adequate for most track applications.
Some pics for Duncan.
33GTR front and 32 rear
33 GTR
32GTR
33GTR
My custom box prototype on the track car using the std air filter and an internal bellmouth from the HKS pod on the inside top (the only good part of a HKS filter). It's a tight fit around the filter so the tape is only to hold it in position and the afm is mounted directly to the top. The from bar is intended to have slots to help feed it.
It's all good mate, I majored in aerodynamics at the one uni in the country with a Mach 3 wind tunnel or what we call a shock tunnel, amongst other useful stuff.
While a simple approach would be to say that at least an extra 40rwkw would be available given Marks experience above, it depends on what the turbos are able to push, mass flow wise in Marcus' case. I forget your setup mate, but a fair guess would be a bit is available at that flow rate. Negative boost theories are all well and good but turbos have one simple role and that is to drag air in and compress it for delivery to the combustion chambers so it overcomes many restrictions, up to a point.
Mark, having a think about this and were any of the turbo inlet hoses constricting? If the restriction to the inlet was enough there may be some cross sectional reduction in the inlets between afm and turbo which is a sure way for the restriction to increase so limiting flow. If hard pipes were used, for example, then they would resist the negative pressure and allow the flow to continue. So just a thought.
 Share
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
