Cheers, I guess that detail is what we are after and is going to have to help the situation :P What I'll endevour to do is get before and after on the dyno and see what happens.
Abu - thanks for the input though the example you give sounds like it doesn't assist what we are after, unless you did the runs with the bonnet down?? What I am talking about is when the bonnet is down and you run the risk of heatsoaking everything... I'd like to know how much can be gained by going from an exposed pod in the engine bay to a decent cold air setup.
  • Replies 63
Just pulled a R32 off the dyno back to back testing pod and airbox:
HKS gt2535, Z32, PFC and std airbox.
with airbox and consecutive pulls lost power to the point of detonation, had to remove 8 degrees of timing comapred to first run to stave of det..
fitted pod, alloweed 10-12 degrees more timing after consecutive pulls and made 12-15rwkw more....
real word and a regular SAU'ers car.
Awesome, thanks for that. Bonnet up or bonnet down?
Changing the intake pipe to silicon intake pipe and putting a 3a air filter on it. Will make a partition up on the weekend or even a full aluminum shield and maybe some sort of CAI feed from the bar then bring it back
See if that makes a difference
did the airbox/pod have a cai?
Standard air box with paper panel filter, no CAI
Down
9/10 people dont have proper set up CAI systems.
they just have a fat pod hanging right in the endgine bay doing the worst job ever.
i dont see how a airbox can possibly out perform a properly set up pod setup. especially at high hp apps. airboxes just dont suck as much air compared to pods.
only times i hear ppl have gains is when they are comparing it to a naked pod sucking hot air, which is no suprise if it loses power.
my 2c
my 2c
What do you consider a proper pod setup?? Or a naked pod setup?? My pod filter sits where the stock airbox goes but has no shielding at all. Yet.
then it sucks up water and all other types of shit
I cant remember the last time I hit standing water deep enough to submerge my pod (would have to be over a foot deep to ever touch the filter). That being said I have a splash guard on the rear (same as used on the back of a std side mount intercool) and a baflle in front of the filter so it cant be directly hit by water coming though the opening in the bumper or splashed by puddles etc.
If your planning on driving through creeks/shallow rivers maybe buy a snorkel :D
I will assume bonnet down but was the pod shielded at all?
I run no guard lining and GTR front bar, on a bad raining day I get water in the engine bay (behind the head light where the cooler piping goes through the floor)
Weather thats because the bar has a lot of openings, weather its because I have no guard lining, I don't know
All I know is if I had a pod filter behind my bumper, my engine would be fkd by now
I find that even just having the cold air intake routed towards the pod it routes in a lot of dust and bugs very quickly and clogs up that area of the pod filter. Surely having it exposed behind the bumper will only amplify that.
I've got a breathable stocking over my CAI now and it filters out a lot of dust and bugs and it doesn't take long to have the stocking start catching everything.
Edited by KeyMaker
defiently not ur setup sorry buddy lol.
enclose the pod away from inlet temps, and feed it outside air from the bumper or something with some sort of tubing.
especially on cold nites you FEEL the difference.
everyone here should know how hot air and cold air affect turbo performance
If your planning on driving through creeks/shallow rivers maybe buy a snorkel :P
We had a Silvia who's SR20 my workshop rebuilt come back in, which had its pod down at the bumper... It was around that time we had very heavy rain at the start of this year.
Pulled it apart and found number 3 cylinder rod was bent like a banana! Cannot compress a liquid!
No shallow river or creek driving, driving to work on the road during heavy rainfall period
Lowering the intake charge temp as much as you can, as often as you can it all you gotta aim for
So keep it lower before the turbo, and after the I/C. What happens from the turbo to the I/C is minimal as the air isnt there long.
R33 GTS-t airbox is much better than the R32 one from what i can gather, it also the point of the panel filter inside the airbox is of as much importance as the airbox itself :P
Shit filter, shit flow which would give problems mentioned above which is something to think about considering GTR's with good panels flow 350rwkw without a worry
I cant see why you would put the pod in the engine bay if your worried about inlet temps... stick it down in the bumper where it can suck on mostly ambient temp air and be done with it.
Dunno about you but I have a 4" intake and a filter to suit, its not gonna fit in there without chopping stuff. I had an intake like that with my old Honda and it worked superb though, and in that size (~3") you I am pretty sure AEM did a fitting which basically blocks off the air flow if a restriction appears - ie, filter submerged.
    • 65601-05U00 is the hood latch. 62550-08U31 is the support that holds it to the radiator core support. They are all super discontinued so I don't really have any great leads on how to source this stuff.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
