Hi guys, the Aussie conditions have taken their toll on my HKS Hypermax II front coilovers and i'm wondering if there's anywhere in Melbourne that rebuild them? Or interstate if need be (saw a post ages ago that said a place in queensland rebuilds them)?
The top oil seals have been leaking from dirt rubbing away in them so they're getting really squelchy (one side more thatn the other) and are pretty much f**ked.
Does anyone know of any places preferably in Melbourne (and western side) that are able to rebuild Jab suspensions to a decent quality? I'd rather not have to shell out for a full new set.
Alternatively, anyone want to sell me some passable stock front suspension for under $100 for in the mean time?
Thanks
https://www.sau.com.au/forums/topic/187055-rebuilding-hks-suspension/
Ghost from the past :down:
Give 'TruTrack' a call mate, the guys there might be able to put you on the right path.
Forget their number, but yellow pages should do the trick.
I had a place on Mt Alexander road 'attempt' to rebuild my items a few years back, failed in 6 months, needless to say i wont go there again :ermm:
  • 1 month later...
Zac at TruTrack was real helpful but would still have had to send them away to be done. Thanks for the help mate.
I found a place local though that was able to rebuild them for under a couple of hundred $$$ because the shafts were still in great condition and only needed new seals/oil/gas.
Leslie & Sons Shock Absorders (need to look them up in the white pages) was the place and i haven't had any problems with them yet. They were also able to soften them up a bit which was much needed. At this stage i'd recommend them because there doesn't seem to be any other options in Melbourne and looks like they've done a good job.
Thanks
^^ yeah most of these guys send em north to shocker reco in qld and they are fkn average to say the least had 3 sets done myself and athid a mate of mine had a set done and all have failed 6-12mths down the track.. i bet thats where R31NISMOIDS ended up.
Best bet ive found is to use Motocycle suspension specialists as they actually give a shit and know what they are doing, a bad setup on a bike doesnt annoy you it tends to kill you :rolleyes: they can get shafts hard chromed and titanium nitrated too (anti stiction coating).
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
