Rebuilding Hks Suspension?
Steg33
 Share
Hi guys, the Aussie conditions have taken their toll on my HKS Hypermax II front coilovers and i'm wondering if there's anywhere in Melbourne that rebuild them? Or interstate if need be (saw a post ages ago that said a place in queensland rebuilds them)?
The top oil seals have been leaking from dirt rubbing away in them so they're getting really squelchy (one side more thatn the other) and are pretty much f**ked.
Does anyone know of any places preferably in Melbourne (and western side) that are able to rebuild Jab suspensions to a decent quality? I'd rather not have to shell out for a full new set.
Alternatively, anyone want to sell me some passable stock front suspension for under $100 for in the mean time?
Thanks
Ghost from the past :down:
Give 'TruTrack' a call mate, the guys there might be able to put you on the right path.
Forget their number, but yellow pages should do the trick.
I had a place on Mt Alexander road 'attempt' to rebuild my items a few years back, failed in 6 months, needless to say i wont go there again :ermm:
  • 1 month later...
Zac at TruTrack was real helpful but would still have had to send them away to be done. Thanks for the help mate.
I found a place local though that was able to rebuild them for under a couple of hundred $$$ because the shafts were still in great condition and only needed new seals/oil/gas.
Leslie & Sons Shock Absorders (need to look them up in the white pages) was the place and i haven't had any problems with them yet. They were also able to soften them up a bit which was much needed. At this stage i'd recommend them because there doesn't seem to be any other options in Melbourne and looks like they've done a good job.
Thanks
^^ yeah most of these guys send em north to shocker reco in qld and they are fkn average to say the least had 3 sets done myself and athid a mate of mine had a set done and all have failed 6-12mths down the track.. i bet thats where R31NISMOIDS ended up.
Best bet ive found is to use Motocycle suspension specialists as they actually give a shit and know what they are doing, a bad setup on a bike doesnt annoy you it tends to kill you :rolleyes: they can get shafts hard chromed and titanium nitrated too (anti stiction coating).
 Share
    • Am I correct in thinking that even if you flat a rear, you'll have to fit the spare to the front anyway? I'm thinking that the LSD will thank you for not inflicting a massive permanent speed difference on it.
    • Time for millspec wiring, MoTec electronics package, Bosch Motorsport ABS, let's goooooooo!!!   Maybe as @MBS206 suggested, just swap out those stupid blue relays near the ECU plug.
    • My only regret with the NC MX5 was no space for a spare, even a space saver doesn't fit in I do have a couple of those puncture repair spray cans, but if I get a large puncture, or sidewall damage, I'm screwed until a tilt tray turns up I'm thinking I might get one of those 4WD style of puncture repair kits that have that rope stuff and glue, whilst it will kill any hope of saving a tyre, it might help getting me out from some backwoods road far enough to find a actual tyre shop if the first can of tyre fix doesn't work I'm keen to see how your new toy pans out Uncle Duncan, I'll be moving to the Highlands next year, you'll need to shout out if your heading to Wakefield, whilst I've lost my balls for happy laps, I still love watching those that can
    • Yeah not sure what the warranty was, but it will be years outside it.  I've shot Link a message, will see what happens, I'm told their support is good. It is a plug in, so its a Link board in a factory case, very easy to access both sides of the circuit board by removing the top or bottom cover. To be fair the the Link, although I've checked to the factory connections and wiring specs, as we learned with Neil's car in the early days not all ECUs source power the same way. He'd been running a factory ECU with no trouble for years, but when we plugged a PowerFC in it wouldn't start up, just kept cycling power on and off. We worked out that the car was missing one of the 10a fuses "Electronic Parts", and to Neil's knowledge it had never been there. Turns out the ECU pulled its main power from that source not the same place the factory ECU did.  Point being....there are multiple battery and ECCS power sources in the factory ECU, and multiple grounds as well....not telling from the outside exactly what the Link uses (and doesn't use)
    • Now, thanks to sonicii, onto the uneven floor from a tyre sticking 100mm into the boot space. I looked into options to raise the floor to the level of the tyre, and ended up going Extruded Polystyrene (XPS). EPS is what I normally think of as polystyrene, the annoying tiny balls that get glued into a flat sheet but XPS is quite different, much firmer and doesn't crumble if you touch it with anything. I also looked at things like heavy duty seating foam but XPS seemed like the right way. I picked up 3x 1200x600x50 sheets for $40ea. Initially I was looking for 100mm sheets because I needed to make up a 100mm gap, but as it turned out 50mm was available, much easier to work with and made it simple to store the tools I used a simple 15cm foam cutter to make the shapes. With some practice I was able to make reasonably clean cuts but I don't think Clark Rubber are going to be calling me to offer a job. https://www.ebay.com.au/itm/405092315205?var=675175481574 First layer in place, 3 dimensions are tricky! Second layer in place, bringing it to level with the top of the spare Cutouts in the top layer for the tools With floor back in place, nice and flat with 100mm stolen but no real impact on usability
