Hi everyone~!!
My r33's shockers need replacing soon as they are leaking... and i'm not sure what brand or what kind of shockers are suitable for my car...
my car already have lowered springs on (not sure what they are it was like that when i bought the car) and i like the height as it is...
as i spent a fair bit of money getting the car, i wanna minimise on spending too much money at the monent, but i wanna get a set of reliable and confortable shockers,
anyone got good ideas? Kyb a good brand? how much should i expect of fitting?
Cheers~!
https://www.sau.com.au/forums/topic/187056-which-shockers-should-i-get/
As posted in your other thread:
If you dont want the cost of coilovers, but just looking to replace the shocks see my review (and other opinions) here:
http://www.skylinesaustralia.com/forums/t174248.html
See the guys at Car Torque for your KYB's
great~!! i got set of kyb quoted for 640, but yours from car torque seem to have a better price... do they have different models for r33 in they kyb range? (and where is car torque?)
cheers~
cheers~
Yep, thats probably their normal price. Get a price from SA Suspension Centre:
http://www.sasuspension.com.au/contact.htm
and either get Car Torque to match it (if they are closer to you) or you could just buy from them.
Car Torque is at North Terrace Kent Town (just next to the city) and SA Suspension is at Ween Rd Pooraka.
And in Australia, they only sell KYB Excel G. I enquired all over Australia to see if they have different models and unfortunately they dont.
Hope this helps some more :no:
Edited by Hotwire
Go into Car Torque, they gave me a good price, just mention you're from SAU. I just got a set of KYBs from them and got a pretty good discount. I'm happy with them for what i do.
When you go in the door go to the left and talk to Julie. She's really nice and will help you out :no:
Hope this helps some more :)
great help~!!! thanks heaps guys~!! i'm gonna ring car torque and get some price~!! cheers again~!
Andz: Suspension is actually really easy to fit yourself. Get some quality springs (Whiteline, NOT kings) and the shocks of your choice and have a go fitting them yourself. If you dont want to do the fitting, i'm sure there are a few shops around that will do it for you, Action Suspension at Edwardstown comes to mind. Generally steer clear of Pedders though ;)
Andy see if Sydneykid can get the group buy Bilsteins/Whiteline setup for your GTR. Keep in mind almost ANYTHING you buy that is non-coilovers will be much softer than the stock GTR ride - I think that is a good thing - but you may like it hard - if you don't, the Bilsteins are firm without being ridiculous.
why do you not want adjustable coil overs?
finding out you ride height is as easy as tape measure from center of your rims to the top of your guard or from a level surface ground to guard then when installing new suspension you know what height it was and where to set it :thumbsup:
I think they be talking about a Coilover not a Coil over........
Being the whole strut, spring and shock all in one with many adjustments! Such as Ryans ISC Coilovers!!
Look if you don't want "Coilovers" then the best bet and most used thoughout Skylines would be the Bilsteins/Whiteline setup! This is what i run because it came in the car when i bought it! Extreamly happy with it! If i were to upgrade id be getting some Coilovers!!
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
