gday guys, having problems with my r33 gtst, while driving under boost if i have 1/2 or more throttle once it hits boost it just breaks down, backfires, sneezes through the pod. changed coil packs 8 months ago because of a previous problem everything has been sweet since then, this is a new problem to me :S changed coil packs (8 months ago) fuel filter (today). when i am outside the car and i rev it right up its fine, not until its loaded up while driving that it breaks down, if anyone has had similar problems/got any ideas that could help me out it would be much appreciated.! also, it sometimes blows the vaccuum line off to my intake plenumn, which makes it idle a bit rougher if that contrbutes in any way..
any help would be MUCH APPRECIATED.
cheeers.
From my understanding, if you run any higher than the factory boost it would make sense to change the spark plug gap.
mine had the same problem when i bought it and started modifying it.
yeah, i changed the spark plugs when i got new coil packs, the thing is that it's just come from no-where, it was running mint, then all of a sudden it was no good. and sice i did the plugs and coil packs, 8 months ago, its ben running sweet up until now?
Did you get splitfires or second hand coils?
yeah, got splitfires, brand newy's its a different sound and feeling to when my coil packs were stuffed, it really jolts the car around when it does it, :S
