Hi guys,
I washed my rear seats (coupe r33) (dont ask) and in the bath tub and now they are really moist inside, its a pain to dry them out... my brother said to take it to panel beaters and put the seats into the oven they have... is this a good idea or any oher way to dry them out?
I was offered to buy second hair s2 rear seats for 100 bucks +freight. what would you guys do?
cheers
Edited by Modena
https://www.sau.com.au/forums/topic/187088-wet-seats-need-help-quick/
I would just use a hair dryer or just leave them out in the sun depending on how the weathers like. Not sure if I'll go out and buy a new set just yet. How long has it been since you gave them a bath?
hairdryer and lotsa towels
towels actually absorb water (their moleculer make-up is such that they 'suck up' water - not just hold water in-between the fibres)
so bung lotsa towels all over it and let them try to soak up some water, then hit it with the hairdryer for a long time
the real question is why did you wash your car seats in the bathtub. and what kind of stains were you trying to remove. jb.gif
Cat pee, the box where I had my cat tipped on the side and the pee trickled onto the seat... bad smell... tried many things to get it out, didnt work, until I got carried away with baking soda... that removed the smell but the baking soda has truelly left its mark on the seats... Hence why they needed a wash.
Yeah get a room as hot as you can and leave it in there. You can even buy one of those moisture trap things, like a little plastic bucket filled with silica crystals that you buy at Woolies or whatever and leave that under the seat while it dries to draw out moisture.
But damn, cat pee, for 100 bucks id just buy the new seats instead of having a faint odour return on warm days :ninja:
any osmosis or capillary action is going to take forever to dry the seats. you're better off pointing a heater at them and squeezing the seat every few minutes. that should at least push some of the water to the outer layers where the heater can dry it, then squeeze again and repeat.
it's going to take a long time to dry the seats out completely though.
Did you end up getting the smell out in the end? Or did you just purchase new seats because you got sick of waiting? $65 is cheap.
The smell is out although one part of the seats smells rather damp... dont know if it will come out in time.
I got the replacement seats because to me it seemed too long to wait and I dont want to risk missing out on cheap S2 seats... there are many S1 seats but not that many s2s...
    • It's impossible to convey what it will feel like to get the right torque. But you can develop a feel for it. A 900mm breaker bar is.....f**king huge. I only use a normal ~400mm one. But with 900mm being very nearly a metre, and the right torque being in the order of 100Nm, then you're going to need a bit over 100N of force, which is about 10 kg. So if you practice using the bar pulling up, instead of pushing down, then it will be about the same effort as lifting a 10kg bucket of water. That's what the pressure against your fingers should feel like. Ish. If you use a more typical length breaker, then it's about twice that. So a good 20 litre bucket, or a little bit more.
    • Also, if anyone has a torque wrench around Williams Landing area and can lend it to me for like 5 mins - I got 4 bottles of Furphy left and I’ll throw that in with a Happy meal 😂
    • So today I decided to bleed my brake fluid, which meant to the wheels came off the car at my garage for the first time. I only had a 90cm breaker bar with me and I noticed that some 1 or 2 lug nuts were a bit hard to get loose (from when the shop did the coilovers) Now.... when it came to putting them back on, I didn't want to put all my weight and overtighten them. So I hand tightened as much as possible and then put normal pressure on the edge of the breaker bar and tightened it until I couldn't turn it anymore without putting in an effort. Do you think that is tight enough? Or is that still too tight?  They are tighter than finger tight. Last thing I want is to have them strip or warp sh*t. But hard times mean I can't just go down to Supercheap and get a torque wrench 🥺
    • Dunno what to tell you, when I look at it on Consult I can see this warmup timing map kicking in around 40C coolant temp and it sticks around for a while:  At part throttle on the normal base timing map it peaks around ~43 degrees of timing or something like that, this warmup timing map drops it to like 12-15 degrees.
    • I don't think that's what you're seeing. Something else doing that. The only time I've seen it get so retarded is when it's trying to control idle (in which case we're not talking about mapped timing tagets anyway) and when there is an extreme coolant temperature sensor fault. The RB26 ECU is essentially the same as the 20 ECU and I knew that ging inside out. There is no facility for it to retard that heavily on cold start. The OEMs never used to do it back then. I mean, shit, the catalyst is abotu 3 miles down the exhaust anyway. Early light-off was just a twinkle in some EPA arsehole's eye back then, not a regular engine control strategy.
