For those that don't read the motorsport section of the forums there is a track weekend on down at Phillip Island on October 20-21st being held by PIARC
Entry Forms and Sup Req's are here: Click Here
Saturday is free practise (non timed unless you bring your own) and free driver training is available if requested.
Sunday is a full sprints day.
There are a few guys coming from interstate for this event as well including John from Unique Autosports with his Zed.
A few people are doing both days so consequently Brisby is organising some accommodation for the weekend. If anyone is keen to come down and stay and have a beer or 2 please post up here.
Cheers
https://www.sau.com.au/forums/topic/187095-phillip-island-oct-20-21/
  • Replies 96
I will be there as I've had the nod from a certain workshop that all will be tiggedy boo with some "unscheduled" maintenance that was required after Winton.
I will be there both days.
Will be good.
Regards
Andrew
Edited by BBGTR
Will be good.
Regards
Andrew
Good to hear Andrew, no doubt I will get THE CALL anyday now....
Be good to see about 10 cars doing sub 1:50's on the day...
Can't wait...
I should be there Saturday, can't be there on the Sunday, not happy.
I wonder if i can get that sub 50 before BB on the Saturday.... come-onnnnnnnnnnnnnnnn!!!
I'll be driving like an 18 yo on L plates for a while until I get used to the car. You are in with a shot, but not for long. That and the fact my tyres are nearly unroadworthy. :worship:
Ahhh I hear excuses!!!! hahah
Good news for me then :D It will take you less time to get used to it than you realise... you'll probably run a 49 in the morning... then it will take you all weekend to run a 47 :P
i would love to come along, i havent been out on the island before. damn shame that my car is in the panel shop at the moment!
i might try to convince a mate to come down to watch on one of the days.
maybee one of you could take me for a ride around the track! :)
So is your car ready for this weekend BB?
I haven't heard yet, but have been too busy to ask.
I've annoyed Ben a fair bit lately asking about various changes, so one more "are we there yet" and it will probably come back in pieces, or worse making 140 KW.
Fingers crossed, accomm booked and leave pass organised.... :D
So, i need new rear rotors and fuel tank before the weekend. Tryign to find some rear brembo calipers so i can run better rear rotors...so if anyone knows of any for sale! Im hoping to make it but may be easier to just park it. Engine was knockign a little on the weekend as well...lol little wonder with the boost gauge saying 1.6bar at the top of 4th gear (Ben ha spreviously told me that the gauge reads higher then what his pressure sensor on the dyno reads, so probably more like 1.3-1.4bar:)
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
